Valve Clearance
Dose anyone know if the clearance specs on the 2.2 are the same as the 2.3?
The specs below were provided by Ken1997TL for the F22B1.
F22B1
Spark Plug Gap = 0.039 - 0.043
Ignition Timing = 15B
Fuel Pump PSI = 38 - 46
Idle Speed = 650 - 750
Valve Clearance: Intake = 0.009 - 0.011 Exhaust = 0.011 - 0.013
(yes thats in inches)
F22B1
Engine Code: F23A1
Spark Plug Gap: 1.0-1.1 (0.039-0.043)
Ignition Timing: 12 +/- 2
Idle (w/ headlight and cooling fan off): 700 +/- 50
Fast Idle: 1300 +/- 200
Fuel Pressure with regulator vacum hose disconnected (psi) 47-54
Valve clearance (Cold):
IN: 0.24-0.25 (0.009-0.011)
EX: 0.28-0.32 (0.011-0.013)
