Valve adjustment and timing belt
Old Mar 21, 2003 | 10:12 AM
theartist170's Avatar
3rd Gear
Hello,
The car: 1997 CL 2.2 automatic with 85,000 miles.
When do you guys usually adjust the valves. Is it normal for a car to have the valves ticking after only 20,000 miles past since the initial adjustment? Also, are the timing belts known to snap or am I still safe? Lastly, are the automatic transmission problematic on the 4 cylinders or is this only when they are mated to the V6?
Thanks in advance.
Old Mar 21, 2003 | 11:19 AM
VXCL's Avatar
AWD Torque Monster
the 2.2s always tic, but yeah i have mine done bout 20,oook ago and its needs it again. depends how hard u drive the car i guess. my car likes to be at 5500+ rpm.
yes the if th ebelt snaps on the I4 you will get some nasty engine damage. bent rods etc.
also the i4 trannys aren't as troubled as the v6s. i drop gears in my slowmatic all the time. works like the day i bought it. but then again we arent makin 200+ hp.
Old Mar 21, 2003 | 11:25 AM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
do you need to adjust the valves on the 3.0? i havent had mine done yet. how much does it cost or can you do it yourself?
Old Mar 21, 2003 | 09:24 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
On the 3.0, you adjust them (or have the shop adjust them) only when they're noisy.
http://images2.fotki.com/v18/photos/...8/valve-or.jpg
http://images2.fotki.com/v18/photos/.../valve2-or.jpg
http://images2.fotki.com/v18/photos/.../valve3-or.jpg
Old Mar 25, 2003 | 07:46 PM
23's Avatar
23
About this valve adjustment, My car is sounding like a sewing machine and is idleing extremely hard. Could the valves be the problem? It is still idleing between 690-710 which is normal but it feels extremely rough. I have never had them adjusted and I have about 53000 on it and have went though 1 bottle of N20. Any ideas on the hard idle. It idles hard weather I run rich, lean, or stoich so im stumped here.
Old Mar 25, 2003 | 10:19 PM
VXCL's Avatar
AWD Torque Monster
mine is idling hard now also. valve adj at dealer cost bout $180
Old Mar 26, 2003 | 06:28 PM
23's Avatar
23
Think that might fix it?
vaughanml2
Nov 1, 2021 10:16 AM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
merc009
Sep 14, 2015 06:43 PM
Tsov Tom
Sep 6, 2015 07:56 AM
asahrts
Sep 4, 2015 05:55 PM
