UR pulley install?
Old Jan 20, 2004 | 05:57 PM
6rian's Avatar
UR pulley install?
is it hard to install unorthodox racing pulleys, all 3 of em? should i take it to a shop to get it done or is it possible to do myself? thanks!
Old Jan 20, 2004 | 06:02 PM
tommyleecl's Avatar
im about to get pulleys, and i to need to know the answer, also, which ones are better, the ur pulleys, or the aem?
Old Jan 20, 2004 | 07:57 PM
TeamBlurryCL's Avatar
TEAM BLUR So. CAL
yeah install on those are a bitch. just get them installed. you could fuck with the belt when you install it. or worst case, you install it wrong and a pulley falls off. aem is better for daily drivers, ur is better for track.
Old Jan 20, 2004 | 10:37 PM
6rian's Avatar
do i need anything else except the pulleys themselves like new belts?
Old Jan 21, 2004 | 08:17 AM
fusionnv's Avatar
Gimmie my points Biatch!
Yeah u probably need new belts. They changed the size of the wheel and made it weight less. Pulleys are a bitch to change I heard because it on really really tight esp the crankshaft. I read some dudes needed an air gun to do it. There tons of debates if the pulleys fuk up the engine or not. I personally wouldn't recommend the crankshaft pulley but that is the one that gives the most hp.
Old Jan 21, 2004 | 12:15 PM
6rian's Avatar
how do i know what kind of belts to get and what size?
Old Jan 21, 2004 | 12:51 PM
fusionnv's Avatar
It should be on a slip that came with the box or belt came with the pulleys. Otherwise u have to call them and ask. They probably give u a napa or some other popualur brand name item number.
Old Jan 21, 2004 | 01:26 PM
99CL's Avatar
blah blah blah
Belts aren't that hard. Just get the Gate belts they recommend, fits prefectly. Size will be on that paper when you bought the UR pulleys. I would say the crank pully is the hardest to put on. Of course I didn't do it, my brother installed them for me...hehhe
Old Jan 22, 2004 | 11:16 AM
Bluesman's Avatar
Sign: Slippery When Wet
From what i have read and talked to people about you have this backward. This is especialy true if you go with the OBX OEM size pullies.
Old Jan 22, 2004 | 02:38 PM
TEAM BLUR So. CAL
UR lightens the crank pulley, which isn't very good for daily driving. AEM does not.
Old Jan 22, 2004 | 04:32 PM
Bluesman's Avatar
Explane how this is not good for daily driving?
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
BoricuaTL
Apr 8, 2016 01:08 PM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
TxRzrBk
Sep 17, 2015 01:07 PM
iCrap
Sep 11, 2015 06:21 PM
