uhh need help with brakes
can someone tell me how to install brake pads in the rear? i got the front..but the rear are a bit different. i cant get the older brakes out to get the new ones in. someone help its driving me crazy!
To get the caliper piston back in, you have to screw it back in with a large flat head screwdriver.
For the pads to come out. Did you take out the 2 bolts holding the caliper onto the bracket? After you do that and take the caliper off, they should just be like the front wheels.
Also, if you're having trouble getting the caliper to slide away by just removing 1 screw you may have to take out both screws and completely remove it. That's what I had to do on the rear brakes. Good luck.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
rockyboy
Oct 2, 2015 10:45 PM
4drviper
Sep 23, 2015 07:42 PM
