turbos
Big Block DOHC Type-R
Turbo's run off low compression. Your 2.3 should be around 9:1, mabey a little higher, but it's perfect for boost. Look for tubo kits for 94-97 Accords.
The Third Ball
Received 4,852 Likes
FMAX makes a turbo kit for the 4cl 94-97 accord that fits our cars. It aint cheap either.
holy crap you weren't joking. 4 grand.... but it's something to look foward to i guess.
if your really think about it like i ddi before you can get a h22 swap for about that much maybe even less. and then you'll have a better change of finding a used h22 turbo kit , ive seen alot sell for about 1700 (used turbo kit for h22)
Originally posted by Sacramento CL
For that kinda money you're better off biting the bullet and getting a new car. G35 Coupe anyone?
100% Dominicano
I think if you're a car fan and you like your car you should hook it up no matter whether people tell you it's worth it or not. If you want it to look bad ass, or be a sleepr quarter miler then do it. When you truly get sick of your car, or it decides to retire on you then you move on. I think your car modding life will be happier if you do it like this.
Originally posted by Zerostatic
Yeah but if your the type of person that chills around car forums you'll probably blow a wad of money hooking that up.
Old Timer
you can turbo the f23 motor just dont go above 7 or 8 psi i turboed my f23 a few years ago and blew the motor in 2 weeks....just be careful
you can find used kits for accords all day on the interenet...
i would say you are gonna be happier with doing an h22 swap..i know i was....but then that got boring after a while so i had to turbo that too....
either way you can make the cl reasonably quick
Old Timer
Originally posted by LvMyCL23
what boost were you running? and if i blow the motor then i'll have to get an h22.... mua haha
The Third Ball
if i did turbo the f23 then decided later i want more power and swap for an h22 how hard would it be to swap over the turbo?
Gimmie my points Biatch!
who got the best deal?
the CL tranny is better for turbo than the prelude i believe someone said something about "longer" gears i guess it would allow the turbo more room to spool?
Comrade Stalin
The only thing about turbos that is engine specific is where to mount, and where to run tubing. The turbo itself surely can be used again, but you would need new plummin for her
Old Timer
turbos are not made specif for each vehicle with the exception of deisel turbos
the cl tranny will work with the h22...for both n/a and f/i
The Third Ball
you could deffinately swap motors after you turbo all you would have to do is change the turbo manifold (header) you may also have to modify some of the piping ...but....if you get an f-max kit for the cl then later swap in the h22 motor you could just get an exhaust manifold for an h22 from f-max ...then you wouldnt have worry about modifying the piping..
thanks ac-l.com
joflewbyu2
10-08-2015 11:16 AM
