turbo question
Old Sep 5, 2003 | 05:49 PM
clstyle's Avatar
turbo question
wats up guys
is it possible to use a twin turbo
from a toyota 94 supra?
is it possible to modify to make it fit?
anyone
Old Sep 5, 2003 | 06:47 PM
d98clturbo's Avatar
Old Timer
yes you can use the turbo...NOT the manifold though...you can pretty much use any turbo as long as you have the right manifold for it...
what motor do you have
Old Sep 5, 2003 | 06:55 PM
JLai's Avatar
Cause stock sux.
Not sure if you're gonna be able to run it sequential.
Old Sep 5, 2003 | 07:24 PM
clstyle's Avatar
hey i got the stock
2.2cl motor
5 speed
so you guys think i can be done
fawkin awesome
tell me more
Old Sep 5, 2003 | 07:25 PM
clstyle's Avatar
i got the 2.2 cl motor
what is that h22
f22 what is that
Old Sep 5, 2003 | 07:42 PM
d98clturbo's Avatar
Old Timer
to be honest it is pointless to try to run a twin turbo setup on a 4cyl motor....just use one turbo
Old Sep 5, 2003 | 07:44 PM
clstyle's Avatar
you think it would be overkill
98 turbo
if so would i be able
to use one turbo
Old Sep 5, 2003 | 08:26 PM
JLai's Avatar
Cause stock sux.
Are you sure you know what you're doing? It don't sound like it if you don't even know what engine you have.
Old Sep 5, 2003 | 08:34 PM
ApocalypseCL's Avatar
Old Sep 6, 2003 | 09:11 AM
d98clturbo's Avatar
Old Timer
98 turbo
to use one turbo
i would say use only 1 turbo but DONT use one from the 2jzgte motor. its too small....you would be better off with a T3/To4e turbo or even the one i have which is T3/To4B...(which is too small for me)
Old Sep 6, 2003 | 09:48 AM
clstyle's Avatar
hey d98
can ya please break that down for me
it seems like your an expert on the subject
Old Sep 6, 2003 | 09:55 AM
97Cl22's Avatar
Comrade Stalin
A T3 is a turbo made by a certain company. If i recall right they makes T1-T5. T3 is a pretty decently mean turbo, especially if you keep stock internals. If you upgrade your stock internals a T3 would be safer. And you don't want to use twin turbo because a four cylinder doesn't have the displacment to spin up two turbos.
Old Sep 6, 2003 | 11:06 AM
d98clturbo's Avatar
Old Timer
that first statement i am not too sure about... i have never heard of a t1 t2 or t5 turbo i maybe wrong though
the ideal turbo for a I4 honda (street driven) is a T3/To4... single turbo...there are many different trim levels for each turbo..each trim level will yeild different power levels....so usually you want to figure out how much power you want to make before you purchase a specific turbo (i didnt do this) then you need to figure out what kind of power band you want ...do you want quick spool or lag...the bigger the turbo the more lag
for instance my turbo is T3/To4B with aT3 0.63 A/R ratio turbine housing with a stage II wheel and a TO4B compressor housing with a Super V wheel...this is relatively small so it spools up really quickly.....i get full boost(15psi) at 3300rpms..the down side to this is that the turbo will run out of breath really quickly (a problem i am having right now) so for an f22/3 motor this turbo that i have is pretty good cuz you reach full boost really quickly and because the motor only revs to 6500 rpms you wont have the problem of the turbo running out of breath...(i do cuz i rev my motor to 8000rpms)
i am not sure if i answered your question but hope it helps
Old Sep 6, 2003 | 02:26 PM
CLUofI's Avatar
337
I would say buy purchase a turbo kit and have a shop install it.
hey d98
Old Sep 6, 2003 | 02:29 PM
clstyle's Avatar
yea like the kit from fmax right?
Old Sep 6, 2003 | 03:50 PM
d98clturbo's Avatar
Old Timer
tru...that is the easiest thing to do
Old Sep 7, 2003 | 10:07 AM
clstyle's Avatar
so forget the turbo of a 94 supra, right
yea i just wanted to know if i could be done
thanks for the help guys
Old Sep 7, 2003 | 05:24 PM
JLai's Avatar
Cause stock sux.
T1/T2 i haven't heard of either...
T5... ---> Think Volvo
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
mvidal6
ILX
Nov 14, 2015 07:43 AM
navtool.com
Sep 25, 2015 05:15 PM
