Turbo?
Swaps? $3000 for 50HP? :(
Your engine will wear faster.
Your fuel economy depends on your fuel set up. If you use the fuel set up that comes with the kits, most will only add fuel under boost.
If you stay out of boost the economy will be the same. Thats tough to do once youre hooked.
An SC is going to need more fuel any time the throttle is moved. There's no such thing as driving with no boost from a supercharger. At low RPM its adding more air than stock so itll need more fuel.
joflewbyu2
10-08-2015 11:16 AM
