Transmission Fluid Quest.
Old Jan 28, 2006 | 10:52 PM
EddieJP125's Avatar
Marine Gulf War Veteran
When i do the drain/refill, how much drains?...b/c i've seen some ppl say 2.5qts, and other said 3.5qts when i searched the forums...so what is it exactly?...and my mechanic had some trouble getting off the bolt for ATF, do the rest of you guys have this problem too, or was it just that moment for my mechanic and easy for me to do?...and when i install the tranny cooler how much fluid do i need to put in addition to...?
Thanks Eddie
Old Jan 29, 2006 | 10:20 AM
Stew97CL3.0's Avatar
Just did mine yesterday. It took just shy of 3 quarts. Fill it to 2.5 quarts then start checking the dipstick. 3.5 sounds a bit much to me, but maybe with a small transmission cooler it will take about another quart.
Old Jan 29, 2006 | 05:01 PM
Mulk's Avatar
The new ride
3.5 quarts is exactly what you need to refill with, the trans. cooler doesnt require you to add any fluid, the extra hose and cooler itself make a difference of like .1 quarts
Old Feb 1, 2006 | 08:50 PM
Nakamichi's Avatar
~[ô¿ô]~
According to Acura documentation for severe driving conditions...
The drain/fill intervals is every 30,000 miles or 24 months.
Fluid Replacement Amount
2.3 Manual - 2.0 US qt
2.3 Auto - 2.9 US qt
3.0 Auto - 3.0 US qt
No problems removing the drain bolt for the 3.0 here. With the exception my breaking bar is longer than the height I could lift the car and since the bolt is perpendicular to the ground, I had to remove it at an angle.
Old Feb 1, 2006 | 09:11 PM
shnee's Avatar
Land of Pleasant Living
just did my tranny cooler like 2 days ago. no need to add anything at all.. read the directions and the DIY guide and you're good
Old Feb 7, 2006 | 09:16 PM
Pancho's Avatar
No tranny cooler here, but just changed my fluid and the filler bolt was a BYTCH to get off.
Old Feb 8, 2006 | 01:01 AM
Yeah my filler bolt was pretty tight also, I use a breaker bar and a 2' extension to get it loose. No way it was happening with just a 1/2" drive ratchet.
Also, I just did another drain and fill the other day and this time it took a bit over 3L. Last time I had only jacked the car up on the driver side, so I guess I didn't get good full drainage.
SidhuSaaB
May 30, 2020 12:40 AM
steve
Sep 30, 2015 09:23 PM
hpfiend
Sep 27, 2015 06:59 AM
mellsonnj
Sep 24, 2015 04:42 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
