Tranny Fluid change?
Old Feb 15, 2002 | 10:59 AM
djz's Avatar
djz
Music for your Mind......
I have a 97 3.0 with 58,000 miles on it and want to get the transmission fluid changed. Do i have to take it to the dealership to get that changed or can i take it to a good mechanic to change it so i can save some money?
Old Feb 15, 2002 | 11:09 AM
Always Dirty's Avatar
I'm in the exact same situation. I hope somebody answers this....
Old Feb 15, 2002 | 11:10 AM
haiduc's Avatar
Moderator Alumnus
just get some B&M Trick Shift...... quicker response, and some of the 3.0 people say that they chirp on the 1-2 shift.
Old Feb 15, 2002 | 12:08 PM
97AcuraCL's Avatar
My bolonga has a 1st name
I too am in this situation; and although i thank you for the product recommendation; i'm sure to use that it would be smart idea to have the tranny fluid changed; as a result like he asked; can we take it to a good mechanic? Or should this only be trusted with the dealer?
Old Feb 15, 2002 | 12:21 PM
haiduc's Avatar
Moderator Alumnus
you can just take it to a gas stationa nd have them flush the tranny fluid out, and replace it with the one you bought.
check the manual for the specs on how much you need.
Old Feb 15, 2002 | 12:45 PM
So should we take this to mean that changing it yourself would be more difficult than say, changing our own oil?
Old Feb 15, 2002 | 12:55 PM
haiduc's Avatar
Moderator Alumnus
i have no idea where it is on the 3.0's. i would take it to a gas station or jiffy lube just to be sure.
Old Feb 15, 2002 | 08:41 PM
HeavyP_RENAMED's Avatar
changing the fluid is EASIER than changing the oil.
i use trick shift.....it causes the tranny to act funny when cold......
i suggest honda fluid
Old Feb 15, 2002 | 10:19 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
I just took mine to the dealer. So much easier!
Old Feb 16, 2002 | 12:55 AM
Yajarobi420's Avatar
it's just like changing oil. a bolt under the car and a little thingy that says transmission fluid in ur engine bay. just don't get mixed up with oil and tranny fluid.
Old Feb 16, 2002 | 12:56 AM
97cl30's Avatar
5th Gear
I dont know what to say i brought my car to my mechanic who is very good and i got it back today. unfortunetly i dont know if it was a good idea. i didnt even make it home my tranny is shot. I need to know if i can get a new 5 speed auto for my car
Old Feb 16, 2002 | 01:23 AM
ilike2cheez's Avatar
how does it act funny??? so u wouldnt use it again??? what are the noticeable differences bad and good??
Old Feb 16, 2002 | 06:39 AM
gjr2001's Avatar
An Official Cl Whore
Don't take it to a general mechanic!!!! They won't use Genuine Honda ATF. If you do a search on on this topic you will find many post about tranny fluid, especially in Car Talk. Mobil1, Dexron< etc... all advise against using their transmission fluid. They said transmissions vary vastly and each car maker has their own special formula that works best. Some car makers transmission fluid can be inter-changed, but not Honda's. I started a thread not too long ago about this subject, and someone posted the diagrams from the manual on how to change the tranny fluid on the 3.0. I would just take it to a dealer to get it changed, you don't necessarily need a flushing of the transmission. There has always been a debate about flushing vs. just changing. When you change the fluid it only takes out about half of the fluid in the system. Flushing cost a lot more but removes all fluid. The risk in flushing is that the particles in the fluid being flushed out may clog the valves, also if the seals are weak than guess what.
Just take it to a dealer and tell them to change the tranny fluid. They will use Genuine Honda ATF and you will have no worries. Should cost about $30, and remember to tell them to replace the washers after the change, this will lessen your chances of a leak after the system is opened. Oh, Yea you don't have to worry about the tranny filter, there is none.
mada51589
Jan 9, 2025 04:40 PM
Yikes
May 3, 2021 04:29 PM
ghuns
Sep 16, 2015 04:26 PM
Aleax
Sep 11, 2015 11:31 AM
HeloDown
Sep 8, 2015 06:51 PM
