Tranny!
Old Jul 18, 2006 | 01:49 PM
STL+3.0CL's Avatar
Matt
Tranny!
I have tried to find a DIY or a writeup on changing your own transmission fluid, but can't seem to find one. Have any of you guys done it yourself or have a link to a nice writeup? I think im going to drive it up on stands in the front, and jack up the back. Then take off the bottom and completely drain... Refill with ATF adn Seafoam Transmission Treatment; drive about 10 miles and drain again.
From there I would assume I should change the filter (is there a ATF filter on our cars?) Then fill back up with Honda ATF. Does this sound about right? I have 160,000 miles on my car (97) and if I take it somewhere to have it flushed or drained, they dont actually open up the tranny and change the filter.
I dont know im not an expert thats why I need some from you guys.
Thanks,
Old Jul 18, 2006 | 02:53 PM
Nakamichi's Avatar
~[τΏτ]~
There is not a servicable filter in our tranny. You can put an inline filter as an option.
You also can't open the transmission as simple as other manufactuers.
If you want a transmission flush, here are some popular options:
Option #1
1. Drain ATF through ATF Drain plug
2. Fill through ATF Fill Plug
3. Drive around the block
4. Repeat 2 or 3 more times
Option #2.
3. Remove ATF return line from cooler.
4. Attach a separate hose to the cooler which leads to a bucket.
5. Turn on engine and fill ATF at same rate as it drains. (this may require help).
6. Once the fluid has changed color, connect everything back together.
Old Jul 18, 2006 | 03:08 PM
STL+3.0CL's Avatar
Matt
So our tranny as I invision it does not have a series of bolts underneath like others I have seen? But it does have a drain bolt?
Also, what is the recomended amount of fluid for the 97?
Old Jul 18, 2006 | 06:19 PM
Nakamichi's Avatar
~[τΏτ]~
Yep. There's a drain bolt on the bottom of the tranny. It looks like square that you can stick a 1/2" racket into. There's a fill bolt on top of the transmission, which is accessible from the engine bay.
Drain&Fill..........3.1 quarts
Overhaul Fill..........7.5 quarts
Old Jul 19, 2006 | 10:02 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
There's a drain bolt underneath, and a fill bolt on top of the tranny that says ATF, on the 3.0 the fill bolt is a 17 mm
Pham Alvan
May 18, 2021 06:48 AM
Charles Bennett
Jan 28, 2018 08:53 PM
Pham Alvan
Mar 16, 2016 09:17 AM
lanechanger
Oct 13, 2015 10:56 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
