Tire Size
Old Aug 7, 2003 | 11:36 AM
Dank38's Avatar
9th Gear
Tire Size
Will (235/40/18) with 18"x7.5 fit on my 2.2cl w/o rubbing.
They are G-Racing Seki. Check them out. Tell me what you think.
http://www.simpsonwheels.com/giovanna_g-racing.htm
Old Aug 7, 2003 | 08:07 PM
dhauter's Avatar
Should fit just fine. I've got a 215/35/19 on mine, and It's lowered with eibach sportlines.(Specs say 1.7 but it's more like 2.0 to 2.25.) As long as you get the right offset you should be fine. My rims are a 45mm offset. other people say that 42mm is the correct offset, but any where from 40 to 45 should work just fine. Also my 19's clear everything even without rolling the fenderlips.
Old Aug 7, 2003 | 08:28 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
235s may rub. I have 225s with a 42mm offset and a 1.5" drop, and I personally wouldn't go any wider for fear of rubbing.
You may be ok if you have little to no drop.
ron3.7
Sep 20, 2015 11:39 PM
GhostTL09
Sep 19, 2015 01:57 PM
coykiam
Sep 11, 2015 03:43 PM
nuldabz
Sep 3, 2015 05:49 PM
