is there a weather stripping for sunroof?
hi all.. my weather stripping for my sunroof is breaking pretty badly so its leaking a bit.. just wonderin if anyone has redone their weather strippin for sunroof or will you need to replace the whole window roof?
If you're talking about the black strip around the glass itself, that's pretty easy.
Close the moonroof all the way, slide the sunshade all the way back. Remove the 2 plugs and 2 screws that hold on the glass brackets (located on both driver and passenger sides of the glass).
Remove the brackets. Then remove the nuts that were hidden by the brackets. This allows you to remove the glass itself. Mark the front of the glass with a piece of tape, that way you know which way it goes. Have someone inside carefully push the moonroof straight up.
Now you can change the weather stripping.
Install is in reverse order. Make sure that when done, the glass stripping is seated evenly with the roof. Use low pressure water to do a leak check.
Good luck.
Good luck.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
www.acuraautomotiveparts.org has them
hey i tried looking for it but cant find it. http://www.acuraautomotiveparts.org/...s=&view=normal
i need the thing around number 10 but it just says the whole sunroof?
(Mid-Atlantic)
(Mid-Atlantic)
No idea man, man you've asked 2 questions I don't know the answers to, that's really rare. I would check with a body shop
Hello there, I need help finding the weather stripping for my moonroof on my 2001 3.2CL type s.. I went to the local acura dealer and they told me I can only get it with the glass, not seperate cost $631 Please help me find this weather stripping for a lot cheaper and just the molding.
thanks
mike
I live in San Diego, CA
thanks
mike
97BlackAckCL (12-17-2013)
mlody
12-04-2019 02:11 PM
