temp issue
temp issue
as of late it's been 90 degree weather here in jerz.my car's temp has been acting strange..i beat my car on the way to the beach 90 plus sometimes in d3 with the a/c on.when i hit traffic the temp rose above halfway point.when traffic started moving it dropped down quick as it should.now sometimes with a/c on or off when i drive for a bit the temp goes to the halfway point.i looked,as did my mechanic and found nada.sometimes she runs fine for long periods of time,others it runs a bit hot.what could be the problem?thermostat was just replaced also.....
thats what mine does, except i have a hole in my radiator and need to replace it asap.
and i tried stepping on it one time, took it to 4k and as the rpms were going up, my temperature gauge went down to normal and as soon as i stopped, it shot back up above middle
radiatior is what i was thinking,but all appears well.
.what should i check for?what else could it be?just praying its not a headgasket cuz it could be that right?
fyi the temp is almost guarenteed to go up if i beat on her..
.what should i check for?what else could it be?just praying its not a headgasket cuz it could be that right?fyi the temp is almost guarenteed to go up if i beat on her..
i hope mine isnt the headgasket, i just got that changed
btw i didnt find out mine had a hole in it until one day i checked the engine as soon as i got home from an hr drive, and i saw it misting out water and i pull the acc. cable and it started squirting out water
im having the same problem where sometimes the temp rises up over half, but my problem is one of my radiator fans is running slow. i just have to whack it with a wrench til all the sand falls out of it and it gets back to normal for a while. damn all the dump trucks on the turnpike
STOP BEATING ON YOUR CAR AND RACING SATURNS!!! K BYE
Originally Posted by AznX TL
is there anyway to override the fan to have it on full blast all the time?
Btw subbz, I was going to recommend the thermostat and to have your fans checked.
BoricuaTL
Apr 8, 2016 01:08 PM
HOWELLiNC
Sep 18, 2015 11:12 PM
i also got smoke coming out my vents when ac is on.(temp normal)anyone else?condensation?
That's your purge valves
status.you people are what the french call "le poop".......
