tapping valves
Old Aug 17, 2002 | 11:13 PM
sna66's Avatar
tapping valves
i'm sure we all have to deal with this, @least the 4 clys, any resolution?
Old Aug 18, 2002 | 02:28 AM
SumkidwithaCL's Avatar
Turn Signals are good!
Honda engines tend to have loud valves... but if they seem too loud, a valve adjustment may be needed.
Old Aug 18, 2002 | 07:39 AM
niedejb's Avatar
Swaps? $3000 for 50HP? :(
A set of feeler gauges ($10), a 10mm open end wrench, and factory service manual will do the job.
If you wanna try it I'll look up the intake and exhaust valve clearance and post it here.
Old Aug 18, 2002 | 02:21 PM
ilike2cheez's Avatar
im thinking if u tighten the intake and exhaust valves just a lil bit more so that the valves open more wont that add power to the car. I think so since there will be more air coming in the engine and more air coming out with less retriction. The only downside is that the car might idle a little rough. What u think???
Old Aug 18, 2002 | 08:18 PM
niedejb's Avatar
As long as you stay within the spec range you ought to be alright.
Dont want the valves hitting the pistons.
Old Aug 19, 2002 | 02:10 PM
NYCCL3.0's Avatar
i had my valves adjusted at the dealership and it made no difference, they were still loud... about 3 months later i switched to mobil 1 synthetic oil and the valves were noticibly quieter. if you haven't used it give it a try, may help with the noise.
Old Aug 19, 2002 | 02:50 PM
97CL2.2's Avatar
I just adjusted mine last weekend and much quieter... I believe the "bible" suggested exhaust @ 12 and intake @ 10 (maybe it was opposite)... so i did mine at 9 and 11- (.009 & .011)
I also advanced my timing a few degrees... gotta run plus now- at least... but i don't wanna get into that whole "gas" discussion HAHA ... That's JMO!
Since i'm on the subject- i also threw an ignition in... :P ...
Eh... not much difference if any.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
Acura604
20
Aug 5, 2017 12:55 AM
soupi
14
Nov 15, 2015 11:15 AM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
