Supercharged :O
Old Mar 13, 2004 | 04:41 PM
jblaze_RENAMED's Avatar
Commander in Chief
Supercharged :O
Just got a vortech supercharger from a friend and plan on retro-ing it on my 2.2 sometime in the next few months. I just wanted to know what kind of psi i can run safely on it. It's fitted with an 8 psi pulley, but is that the same kind of boost as a turbo would give or are you supposed to run superchargers lower. Any tips on setting it up? Is a boost controller necessary when the s/c is set up with a specific pulley? What addl. parts are necessary for running a supercharger safely (i'm not lookin to run the quarter just want a little extra power on the highways). My plan's were injectors, ignition, plugs, and wires. I would also think that underdrive pulley's are a no-no. Thanks for any help guru's .
Old Mar 13, 2004 | 04:43 PM
Cocoa's Avatar
2600lb CL
safely would be 5-7 psi's. Usualy when you buy them they are running at 7psi stock. hell, have fun, and good luck with it. Is it made for your car?
Cocoa's Avatar
2600lb CL
typo: usually*
Old Mar 13, 2004 | 04:49 PM
Commander in Chief
nope it's just a stand-alone supercharger i'm going to bend all the piping and build all the brackets myself. It's probably going to take a few weeks of steady working to get it to look clean.
Old Mar 13, 2004 | 07:28 PM
red99cl2.3's Avatar
who got the best deal?
damn i didnt even know you could supercharge our engine, how much did you pay for it.
Old Mar 13, 2004 | 07:36 PM
CLpower's Avatar
teh Senior Instigator
nah, 5-7 is pretty significant for a SC. I'd say be on the safer side and do 5 max
Old Mar 13, 2004 | 07:46 PM
lnsyone's Avatar
CL 4 LYFE
yeah 5psi on stock
Old Mar 13, 2004 | 08:02 PM
ayougo's Avatar
B A N N E D
why cant the engine take more psi ? It has a low compression ratio does it not. Inform me on what will be needed to turbo her at 11 psi or more . Thank you
Old Mar 13, 2004 | 08:30 PM
lnsyone's Avatar
CL 4 LYFE
haha do it, dont cry when you blow your motor.
Old Mar 13, 2004 | 09:09 PM
CLpower's Avatar
Turbos boost more then SC's do. For 11 psi i'd recommend building up the bottom end. You could probably do 8 psi safely w/ a turbo on a stock motor.
Having low compression to start doesn't do it, you need to build up the internals to make it strong
Old Mar 13, 2004 | 09:23 PM
JLai's Avatar
Cause stock sux.
neijb or whatever his name did like ~12-13psi on a 2.slow stock block. But then again he had a spare engine ready cause he was expecting the motor to blow.
**Turbo...not SC**
Old Mar 15, 2004 | 04:47 PM
Commander in Chief
Still wondering about the boost controller.
Old Mar 15, 2004 | 05:37 PM
DanMan1464's Avatar
Autobot
run it low first....see how it feels then try going up if you wanna risk it =P start at maybe 5-6?
Old Mar 15, 2004 | 08:22 PM
proaudio22's Avatar
-S namyaC-
Can you afford an intercooler to go along with it? More effect for the same boost.
Old Mar 15, 2004 | 08:54 PM
lnsyone's Avatar
CL 4 LYFE
^^ yep.
Old Mar 16, 2004 | 01:19 PM
JLai's Avatar
Cause stock sux.
Ummm...Superchargers change boost through pulleys. You can't change boost on the fly.
Old Mar 16, 2004 | 01:50 PM
97Cl22's Avatar
Comrade Stalin
Can't you BOV it to control the boost though?
Old Mar 16, 2004 | 02:31 PM
JLai's Avatar
Cause stock sux.
WTF? No.
Old Mar 16, 2004 | 02:32 PM
R1Performance's Avatar
Power of Dreams
Whether the charge is cooled or not could play a big role. If not, I don't think anything more than 6psi of hot air would be smart.
Old Mar 16, 2004 | 02:34 PM
Power of Dreams
On a Vortech (centrifigal supercharger), a bypass/blowoff valve can be used, to bleed off excess boost, or how a normal bov/bypass would work....so yes, it can be used to control maximum boost.
Old Mar 16, 2004 | 02:46 PM
JLai's Avatar
Cause stock sux.
You are thinking of a wastegate. Not a blowoff. And it does bleed off EXCESS boost...But it does not CONTROL boost levels. SC boost levels are pulley dependent.
Old Mar 16, 2004 | 04:58 PM
Commander in Chief
Thanks for the info.. an intercooler is about 3-4 hundred right?? and does that signifcantly drops the air temperature through the supercharger? Another problem im going to run into is where i can fit an intercooler that it won't interfere with the radiator, any suggestions on effective placement?
Old Mar 16, 2004 | 05:06 PM
CLpower's Avatar
move the radiator back
Old Mar 16, 2004 | 05:30 PM
Commander in Chief
Actually now that i'm thinking about it an intercooler is not neccessary with a s/c because the s/c is not using exhaust air (like a turbo) it's using cool air in. If this does'nt make sense to you let me know please.
Old Mar 16, 2004 | 05:33 PM
CLpower's Avatar
true, but they can be effective w/ SC units also, vortech makes a sweet power cooler
Old Mar 16, 2004 | 06:23 PM
JLai's Avatar
Cause stock sux.
I think its called an "AfterCooler"...or something like that.
Old Mar 16, 2004 | 09:51 PM
Power of Dreams
Actually, I'm thinking a blowoff/diverter/bypass valve. And yes, it can control maximum boost level by bleeding off boost , and will relieve boost pressure off engine load.
Old Mar 16, 2004 | 10:11 PM
Power of Dreams
Just to add to the previous post, the reasoning for capping boost with a bov/diverter/bypass, is being able to modify the boost curve with a theoretical higher "pressure" pulley. For example, a smaller pulley to obtain more boost in the lower rpm range, but will exceed maximum desired pressure at a certain rpm threshold. Which can help a small displacement, centrifigal supercharged motor...similar to the effect of a quicker spooling turbo.
Old Mar 18, 2004 | 03:04 PM
JLai's Avatar
Cause stock sux.
So if your pulley makes 7 psi how are you gonna push it to 10 with a bov?
Blow off valves are just secondary safety systems...They protect the intake manifold and engine from boost spikes and overboosting. THATS IT. You can't "vary" a boost level...Only cap it. Thats what an EBC/manual BC/pulley is for...not a bov.
Old Mar 18, 2004 | 03:38 PM
Power of Dreams
An example would be a "10psi" pulley to change/increase your boost curve in a lower rpm range, since a supercharger is rpm dependent...then capping it at 7psi by bleeding pressure, since a "10psi" pulley would be driving the supercharger beyond your desired boost threshold. The bov is used as a wastegate as in a turbo application.
Old Mar 19, 2004 | 12:51 AM
DrDre1443's Avatar
112K and on 1st tranny!
yeah jackson racing prides itself in it's "ingenious" air-to-air" and 'water-to-air" intercoolers. combined with a pulley upgrade they can safely increase boost levels by 3-4 PSI on stock motors with RELIABLE trannies
Old Mar 19, 2004 | 03:07 PM
JLai's Avatar
Cause stock sux.
I know what you're saying...But I'm arguing that you can't UP boost with a bov. Thus you cannot "change it"...Technically, all your doing is minimizing max boost...its still building X amount of PSI...its just that its being bled out before it goes in.
For instance...a 7 psi pulley CANNOT be changed to more PSI.
Old Mar 19, 2004 | 04:20 PM
Power of Dreams
I said it can cap max boost, never said it can increase boost. I think there was a miscommunication somewhere along the lines.
Old Mar 19, 2004 | 04:33 PM
JLai's Avatar
Cause stock sux.
The original question was if you can CONTROL boost through a BOV. You then entered into explaining how it caps max boost. That to me is not controlling boost since you can't increase it. I think that is where we differ in ideas.
BoricuaTL
Apr 8, 2016 01:08 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
k6biv
Sep 22, 2015 02:06 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
simplyjayyy
2G TSX Performance Parts & Modifications
Sep 2, 2015 12:57 PM
