Suddenly running hot!!!
Ok...! My 1997 CL 3.0 spiked a temperture yesterday while sitting in Tampa, FL traffic. This happend once since I got the head/ gasket work done. The mechanic says it is the water pump (blades) because when I get up speed/rpm the temp gauge goes down, but; only to mid-range (normally she stays a lil under mid). Can someone PLEASE PLEASE PLEASE give me some input????
bamaborn74 (03-19-2014)
@ justnspace - THANKS FOR THE REPLY! Yes, she overheated after I purchased her used and was trying to drive her home. I got the head gasket replaced, head machined, new thermostat & switch.
bamaborn74 (03-20-2014)
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
The thermostats are notorious for going bad
"Hot White" Ivory
justnspace- thanks for the info. I ended up replacing thermo, coolant fan switch sensor and the water pump. gauge still goes above half and the fans kick on and brings it down to halfway mark. I will flush the radiator this weekend.
justnspace (04-03-2014)
Temp running high
Bleed all the air out of the coolant system. I am assuming the bleed valve is near the thermostat, on my F22B1 its under the distributor. I know the symptoms of a blown headgasket, I had a 92 Legend that had that problem. I think you're issue can be improved with the maintenance. Good luck.
rockyboy
08-04-2024 10:35 AM
CheeseyPoofs McNut
10-11-2015 11:25 AM
