Step By Step Tune up
Old May 2, 2006 | 08:34 AM
yossi's Avatar
I am looking for detailed step by step and photos on changing plugs, wires, cap/rotor on a 1997 cl 3.0
thanks
Old May 3, 2006 | 12:23 AM
ib_jimmy's Avatar
those tune up is too easy to waste time taking pictures.
-Spark plugs...just do one at a time so u wont mix up the wires.
-new wires on new cap...take one wire out at a time...lay in next to one of the new wires that measure up. use the existing distributor cap in the car as reference. now remove the old wires and plug in the new one. once finish with that you take the distirbutor cap off with the 4 screws/bolts.
-to take off the distirbutor rotor....you should unscrew a screw on the side...if you can access it, u should try to turn the motor buy putting in ur key and kind of tap the inigition...little by little until you can access the screw holding the rotor.
I hold that help.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
