starting problem.
Old Oct 23, 2006 | 02:38 PM
Orlando3.0's Avatar
Fast Foward>Rewind>Play
starting problem.
I have a 3.0 (J30) and for some reason lately, the car doesnt want to start up as quickly. When i turn the key, the engine will crank over and over but wont start. i will do it like three times or so and then it will start. itll run like a champ after that. the starter sounds perfectly normal too. it doesnt happen all the time either, but its is becoming very frequent.
My mechanic said something about a rleay, wasnt sure what he said.
Old Oct 23, 2006 | 03:39 PM
SwervinCL's Avatar
Nom Nom Nom Nom
Possibly possibly possibly a fuel pump and or fuel filter.
Old Oct 23, 2006 | 03:41 PM
PimpCL23's Avatar
contrarian in fashion
took the words right outta my fingers
Old Oct 23, 2006 | 03:43 PM
SwervinCL's Avatar
Nom Nom Nom Nom
Sign language huh... Nice....
Old Oct 23, 2006 | 04:26 PM
wilp99's Avatar
i know these cars are tempremental with being low on gas.. if you have less than a quarter tank try a fill up and start again.. is it keeps doin it, its prolly the fuel filter. or maybee fouled dizzy cap.
Old Oct 23, 2006 | 04:36 PM
Orlando3.0's Avatar
is there any way to test for some of this stuff? i want to change the fuel filter for sure anyways.
Fuel filter will be replaced anyways.
Always have more than a half tank.
Any way to test Distributor?
If fouled dizzy, can I clean it?
Where this relay my mechanic was talking about?
Old Oct 23, 2006 | 04:41 PM
PimpCL23's Avatar
LOL!.. well i can say it to the computer but i doubt he'll hear it
Old Oct 23, 2006 | 08:47 PM
TexasHonda's Avatar
This problem has the appearance of the Main Fuel Relay (MFR) failures experienced by many Honda products. You will need a wiring diagram and a component location chart to locate the relay.
First listen for the fuel pump to engage for about 3 secs when you turn keyswitch from OFF to ON, but no start. If you hear dead silence, suspect a MFR problem.
Check the fuel pump power supply line when you have a no-start condition. If no voltage when key is first turned to ON, then MFR is likely.
good luck
Old Oct 23, 2006 | 11:19 PM
arstraub's Avatar
ur as welcome as cancer
It's warm where you are, so it shouldn't have to do with anything being too cold - which is my problem. Hell, my car shuts off when I put it in gear if it's too cold...damn thing scares the crap outta me!
Old Oct 23, 2006 | 11:30 PM
SwervinCL's Avatar
Nom Nom Nom Nom
Sure it will..... Just YELL..
Old Oct 23, 2006 | 11:39 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Does it click and not start? Or just hesitate, there's a big difference.
cycdaniel
Dec 17, 2019 10:58 AM
obert
Dec 14, 2015 11:36 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
NSolace
Sep 3, 2015 08:02 PM
