starting problem
Old Aug 27, 2001 | 06:00 PM
shatooi's Avatar
starting problem
i have this problem where everytime i start my car it makes that noise when lets say ur car is already on and u turn the key. i figured it's either my starter going out on me or it's a belt slipping. anyone know what it possibly could be??
Old Aug 27, 2001 | 06:21 PM
sak8's Avatar
Does the car actually start, or does it just make the noise and refuse to turn over?
My car was firing the starter very rapidly when I tried to turn it on, and wouldn't turn over. It turned out to be the battery in my case (the battery was dead so it caused the starter to malfunction, but just replacing the battery solved everything).
Old Aug 27, 2001 | 07:02 PM
Kiljaedoen's Avatar
Did you try kicking it. That always works
Old Aug 27, 2001 | 08:10 PM
shatooi's Avatar
the car starts all the time it just makes that nose after right when it turns over.
Old Aug 27, 2001 | 09:35 PM
niedejb's Avatar
Swaps? $3000 for 50HP? :(
You may have the starter pulling away from the flywheel (i.e. bolts loose). Could be wonr teeth on the starter or the flywheel. If either of these are worn you would hear it. On the other hand the solenoid plunger that moves the starter gear in and out may not be retracting like it should. Looks like you wont know till the starters off. Good luck.
Old Aug 28, 2001 | 01:32 AM
shatooi's Avatar
what would you recommend me doing? is it something that can be expensive?
Old Aug 28, 2001 | 11:44 AM
niedejb's Avatar
Are you doing it or having it done? If youre doing it I can tell you what my service manual says for trouble shooting. You have to remove the starter and have a volt/ohm meter. Let me know if you need specifics.
If it was me, I'd start by looking for loose bolts or anything awry, then take the starter off and check the starter per the manual specs.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
