Squeking noise..?
Can't Hold Me Down!
Squeking noise..?
I just put on my camber kit, ingalls, with rubber bushing and it squeks like a mofo when the springs compress alil...what is going on....? and do any of your guy's springs in the rear hit, like the coils hit each other.????
The camber kit needs to be tighten within the torque specs listed. Especially the pivot bolts. Its all moving parts and if you tighten it too much it will squeek. Check the specs and get it tighten the way it should be. The coils do hit sometimes but its not bad. Firmer shocks should solve the problem. When i turn right into a driveway something in the right rear is making a rubbing noise. It could be that the tires are rubbing but i don't see anything. Might be the springs..i dunno.
