Squeaking Noises..?
Squeaking Noises..?
Everytime i turn my car on i hear this squeaking noise from under the hood.....i dont know what it is......it also squeaks a bit when i accelerate.....does anyone know what it could be and what to do to resolve this problem?
also when i hit the brakes to stop, it feels like the car is about to stall and it happens alittle when i hit the gas....the car doesnt drop in rpms but it feels like it does and that its about to shut off.....what can that be???
it might be your wheel bearings, take it to a shop local and have it checked out for free, if you need them or not
mie skweeked a little and it was the bearing so youll never know, some say the belts but i say check your wheel bearing
i got that exact same damn fuckn problem i change my alternator n watever belt and it now it only makes it wen i have the ac running n stuff so what belt or what do i have todo now? i put alittle dressing on it....it helped for like alittle n back to normal again.......... advice plz
if you changed the alt belt and it still makes noise, by process of elimination, it should be the other 2. but you said it only makes noise when the ac is on, it's probably the ac belt.
why don't you open up the hood and let the ac run and try to hear where the noise came from?
2012wagon
Sep 29, 2015 04:21 PM
