Squeaking climate control
Old Jan 6, 2003 | 08:31 PM
Zerostatic's Avatar
100% Dominicano
When I put the climate control I hear a continous squeaking noise (similar to the squeaking a mouse makes) . The higher I put the temperature the louder and more annoying the squeaking. What do you guys think it could be and how can I fix it?
Old Jan 7, 2003 | 01:01 PM
1StGenCL's Avatar
958 & 991
Thats so weird mine did the exact same thing today I have no clue what it could be but it def. was the climate control
Old Jan 7, 2003 | 01:16 PM
23's Avatar
23
mine too out of the passenger side
Old Jan 7, 2003 | 01:27 PM
Slooo97CL's Avatar
happens once in a while to me too...no idea what it is.
Old Jan 7, 2003 | 01:32 PM
CLpower's Avatar
teh Senior Instigator
mine does it on the passenger side, it's pretty constant. I think there may be a leaf in the fan, or the bearings on the fan maybe going out
Old Jan 7, 2003 | 01:33 PM
dogfight's Avatar
Does it vary with fan speed? I had a Volvo that finally burned out a fan motor because the bearing(s) ran dry - or somehing like that. It squealed and screamed depending on the fan speed.
dogfight
Old Jan 7, 2003 | 07:36 PM
Zerostatic's Avatar
100% Dominicano
dogfight
Sometimes it seems that the higher the fan speed the louder the noise. Also, sometimes it seems like then noise stops if I leave the climate control on for awhile, maybe something warms up.
Old Jan 8, 2003 | 12:15 PM
Esti's Avatar
I had a similar noise from my G1 Legend. It was coming from the temp sensor located on the center console. It's basically a little vent with a small fan unit inside which checks the air temp of the cabin . When u turn on the climate control the fan starts spinning and sucks in the air from the cabin. Over the years the fan unit gets really dirty with lint and dust making the fan get out of place and making a very annoying noise.
I got a new unit for about $175 at a dealer.
I'm not sure if the G1 CL has the same temp sensor, but it's worth looking into.
or It could also be a leaf.
Good Luck
Esti
Old Jan 8, 2003 | 12:27 PM
SHYROCK7's Avatar
97 Acura L'Arc~en~CL
hmmm..... mine makes the same noise, but what does it has to do with the "climate control"?
mine makes that "squeaking noise" when i accerate and when i brake suddendly.... (from the driver's side)
i thought it would be coming from the suspension side...
does anyone else has this prob.?
Old Jan 8, 2003 | 03:01 PM
Zerostatic's Avatar
100% Dominicano
My squeaking noise is a continous squeak, which is obvioiusly a mechanical problem, and also only occurs when I use the climate control, it also turns off when I turn off the climate control so there's no way it could be the suspension. We have different problems.
Old Jan 10, 2003 | 04:15 PM
23's Avatar
23
Mine sometimes stops when I slam my fist on the dash above the glove box, but I stopped doing this when I finally realized how close I was hitting to the air bag. I didnt want that thing going off. Also new law passed in IL -----It is now illegal to remove your airbag and replace it with some other object----
Old Dec 5, 2005 | 05:52 PM
acuratl_2nr's Avatar
I know this is an old post but my vent is sqweaking and I can't take this shit anymore... did anyone fix it?? I wanted to check the cabin intake but I have no idea where it's at... only had the car for a few weeks,... I need help...
Thanks,
M
Old Dec 5, 2005 | 06:52 PM
SiGye's Avatar
1998 3.0
I heard that if the climate control makes noise, it could mean the belt on the alternator is loose and ready to go out. Worth a check.
Old Dec 5, 2005 | 06:59 PM
CLpower's Avatar
I replaced my unit, fixed it, but now it's happening again
Old Dec 5, 2005 | 07:02 PM
shnee's Avatar
Land of Pleasant Living
im pretty sure the airbags only go off when a sensor in the bumper is tripped or something.
Old Dec 5, 2005 | 07:06 PM
Smalls's Avatar
Insert Sarcasm Here
it the bearings, 99% sure. I've had mine looked at by a professional.
Old Dec 5, 2005 | 07:14 PM
bearings of what and where can I access them to lube em up ?
Old Dec 10, 2005 | 11:37 AM
Cmon guys,. this is drving me crazy,. help me out!
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
adreano17
Sep 29, 2015 08:48 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
Brandle34
Sep 23, 2015 07:20 PM
