squeak sqeauk .. yet again
Old Sep 15, 2004 | 06:07 PM
MaCe's Avatar
fellow MASShole
ok so there are no TOOLS left in my engine bay like last time ... squeak is back and almost constant belts are tight
thinkin it might be a bearing problem in one of the pumps ... anyone have any problems with these before
i cant tell where its comin from because when i have time to jump out of the car it always stops!!
gettin kinda annoyed now
Old Sep 15, 2004 | 09:07 PM
Hobo's Avatar
Flap.
maybe it stops when you get out cause its just your seat...
Old Sep 15, 2004 | 10:23 PM
MaCe's Avatar
fellow MASShole
nah its not the seat i havent a fawkin clue ... its to the point where im thinkin about bringing it in
Old Sep 16, 2004 | 02:20 AM
ju5tchi11in's Avatar
roomate has a CL too
coming from front or back?
the plastic clip that held the trunk "wire springs" in place had gotten loose and caused squeekage and I didn't figure it out for a long while.
Old Sep 16, 2004 | 08:55 AM
Stapler's Avatar
any of the bearings should make more of a whhhrrrring noise.... should.. stuff
My power steering pump made such a noise when it's bearing was giving out.
Old Sep 16, 2004 | 10:06 AM
r3mix3r's Avatar
I have had the same exact thing for months passenger side front wheel well all you hear is squeak, squeak x 1000 all day long! I have no idea what it is i would pay someone to tell me.
Old Sep 16, 2004 | 01:35 PM
well i have a squeek coming from front passenger side...
but it is my front mounting fork rubber that is not fitting correctly i put in 2 of them on the top side of the suspension assembly because there is to much travel of the shock... for some reason when installing the teins we had lost one of the rubbers and then it moved around to much and ever since it has started moving around to much. so I bought some more rubber to put in there and it just still makes squeeky noises because of rubber on rubber... maybe some grease in there will solve this... perhaps it is your problem lack of grease on the front mounting fork rubber on your suspension assembly.
kmawani
Feb 8, 2023 05:09 AM
2012wagon
Sep 29, 2015 04:21 PM
njresendez
Sep 21, 2015 11:23 AM
forrie
Sep 15, 2015 09:57 AM
jliu6789
Sep 8, 2015 08:02 PM
