sprint camber kit sux assssssssssss
kept the beast
ok first off i have had this camber kt on my car for about 6 months and wheels are straight up and its all good then today goin down the road all of a sudden car is pulling to left like i have a flat so i get out and i do so i air up tire and it sounds like a big whole behind my tire i feel back there and my tire is past the belts its horrible so im out some money getting a new tire what do u think i should do call sprint or email them bitching or what
![Pissed](https://acurazine.com/forums/images/smilies/pissed.gif)
hehehe i had the sprint camber kit for like 7 months...I still have it in the rear...I replaced with Ingalls front kit and people told me the Sprint Kit made the car ride shitty? Didn't make that much of a big difference maybe a little bit. I still hear creaking, squeakin and every day noise.
Im a little confused what ur saying? How did the tire pop? It got real worn down?
Did your tire just wear down real bad? If it did it's not sprints fault...You gotta keep it all in spec...Just because it looks straight doesn't necessarily mean its good alignment maybe camber but the toe could be off. Hitting a bad bump can offset the camber kit. "and it sounds like a big whole behind my tire" what ya mean? And if they wore down, You never look at tire? Tires dont get bald in a day.
The movement has started
Id also try and get a set of neo gens by nitto they mite hold up a little better esp if you live around an area where theres shitty roads where your alignment could be thrown off with everyday driving. The inside tread is made of a different compound to slow down wear due to neagtive camber.
whoa Neo Gen's are better for negative camber? I always see them advertised on the back of every magazine and they actually have my size
I dont see them say anything about inner compound? U jus saying this, or do they advertise that?
i like chicken
i doubt it was the camber kit that screwed up your car.
i have personally seen all of the different companies and there really isnt much of a difference between the products. there are different types like ball joints and adj ball joints etc, but the quality is about the same.
did you get a 4 wheel alignment after they were installed?
kept the beast
ya i got an alignment but im pretty dam sure its the front cause the rear tires have no inner wear and tear to them just fronts esp front left but im getting alignment tomorrow so ill see how things go
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
