Spring install question.
Old Feb 28, 2006 | 08:07 AM
VaTECh_CL's Avatar
Let's go Hokies!
Thumbs up Spring install question.
For you suspension guys, is there anything else important i should know for installing new springs that what is contained in the DIY:
http://www.acura-cl.com/forums/showthread.php?t=171820
Also, skinnier springs go on the front and fatter ones on the back with the compressed looking part of the rear on the bottom, right?
Old Feb 28, 2006 | 08:32 AM
CL Platano's Avatar
Tristate ViP Crew
If you look clearly on the spring it should tell you what goes where atleast my sportlines did.
Old Feb 28, 2006 | 08:38 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Be careful about removing your stock springs, they are very compressed, also you may want a spring compressor to put your springs on your struts. Here's what happened to one of our OG members, Dustbuster when he was puttin springs on
Old Feb 28, 2006 | 10:05 AM
VaTECh_CL's Avatar
Let's go Hokies!
Does that mean i should get two spring compressors? ^^
Old Feb 28, 2006 | 10:19 AM
(Mid-Atlantic)
No, you only need one compressor, as long as you do it one at a time, i was just warning you about compressing and decompressing springs
Old Feb 28, 2006 | 10:31 AM
VaTECh_CL's Avatar
Let's go Hokies!
oh ok, thanks. Yea, i'm getting a compressor from Advance Auto Parts.
Old Feb 28, 2006 | 10:37 AM
(Mid-Atlantic)
Old Feb 28, 2006 | 10:59 AM
ib_jimmy's Avatar
one?! no you gonna need 2 to balance it out. else you gonna end up like dusty up there. you want it fast and easy...take ur whole shock and spring out in one piece. take it to a shop that have a wall spring compressor. have them take the spring out and put ur new one in. got all 4 of mine done for $50 in 15min. go home and install it. done. i did all 4 wheels in less than 2 hours.
Old Feb 28, 2006 | 11:01 AM
ib_jimmy's Avatar
those lil personal size spring compressor are scary. even with 2 holding it, there is still a chance it can pop on you. and everytime i look at those thing it look like its gonna just snap on me. i dont mess with those compressor.
Old Feb 28, 2006 | 11:38 AM
Motohip's Avatar
I'm a llama :(
You have to get a strut spring compressor otherwise it won't fit. I just laid it on it's side in the grass and started unscrewing, then shot the stuff in a box.
Old Feb 28, 2006 | 12:14 PM
ib_jimmy's Avatar
^ are you serious? back in HS, i was helping one of my friend put in set of lowering springs for his Ford Probe. We thought we compress it enought so we start taking off the top bolt. that cap shot up in the air so high it was scary.
Old Feb 28, 2006 | 12:20 PM
ib_jimmy's Avatar
another trick i have to lowing your car. i would place a floor jack under the wheel hub...jack it up, then unbolt the nut on top while the schock is still in place. then lower the jack slowly and remove it like that. put in the new springs, have a big buddy press the cap on while you put the nut back on. once the nut is on, all you have to do is tighten it and put it back on the car. done.
Old Feb 28, 2006 | 12:31 PM
VaTECh_CL's Avatar
Let's go Hokies!
I'm getting a strut spring compressor. You guys got me all nervous now, i'm not tryin to lose my head... lol
Old Feb 28, 2006 | 12:39 PM
ib_jimmy's Avatar
i would take the shock and spring in one piece to a shop and have them remove it, if you never done this before.
Old Feb 28, 2006 | 01:42 PM
Motohip's Avatar
I'm a llama :(
Yeah, that works good too!
Old Feb 28, 2006 | 03:15 PM
Mulk's Avatar
The new ride
oh and be sure to be prepared for some rusted bolts in the rear, you'll need plenty of wd-40, liquid wrench, and a propane torch if they're bad like a lot of ours were.
Old Feb 28, 2006 | 03:32 PM
Cocoa's Avatar
2600lb CL
The compressed side should go up top, not bottom.
Old Feb 28, 2006 | 04:09 PM
Motohip's Avatar
I'm a llama :(
The longer springs go in back and the short (in length and diameter) ones go in front.
Old Feb 28, 2006 | 04:44 PM
shineynitelite's Avatar
NAWWWWSSSSSS
dude dont compress them till you get them all the way out of the car
if you have any questions you can give me a call whenever, pm me for my number
Old Feb 28, 2006 | 04:55 PM
Motohip's Avatar
I'm a llama :(
This is the last guy you wanna call for help when installing springs.
Old Feb 28, 2006 | 05:01 PM
NAWWWWSSSSSS
oh really why is that? ps they are my old springs biotch
^ dont listen to this noob, silly noob mark
Old Feb 28, 2006 | 05:15 PM
Motohip's Avatar
I'm a llama :(
How long did it take you to get them in? Like 2 weeks?
Old Feb 28, 2006 | 05:16 PM
NAWWWWSSSSSS
fuck off that was the first time when the bolt snapped so suck a wang!
Old Feb 28, 2006 | 05:40 PM
VaTECh_CL's Avatar
Let's go Hokies!
lol...thanks for the help guys. I got all my tools and stuff that i need, so thursday should be the day. are there any bolts in particular that i should spray w/ liquid wrench ahead of time or is the liquid wrench pretty instant?
Old Feb 28, 2006 | 05:55 PM
Motohip's Avatar
I'm a llama :(
You suck a wang, you wang sucker!
Old Mar 1, 2006 | 12:13 AM
jimmyeatmud's Avatar
Old Mar 1, 2006 | 06:04 AM
NAWWWWSSSSSS
lol.
the nut and bolt that goes through the rear strut
Old Mar 1, 2006 | 11:58 AM
ib_jimmy's Avatar
Old Mar 1, 2006 | 12:00 PM
ib_jimmy's Avatar
usually the lower bolts and nut will be the one that get rusted due to the salt and snow you guys get there.
Old Mar 1, 2006 | 12:24 PM
(Mid-Atlantic)
I can't wait to see my bolts come off
Old Mar 1, 2006 | 03:15 PM
teh CL's Avatar
mine didn't come off, so we had to them
Old Mar 1, 2006 | 03:44 PM
NAWWWWSSSSSS
dont you have springs already? if not pm me
Old Mar 1, 2006 | 04:20 PM
(Mid-Atlantic)
I have springs, they're in my basement
Old Mar 1, 2006 | 05:28 PM
NAWWWWSSSSSS
they dont do much good there do they
Old Mar 1, 2006 | 10:05 PM
teh CL's Avatar
even on the car their not gonna do much....
Old Mar 1, 2006 | 10:27 PM
ajtcl's Avatar
Peace, Love & Acura
Dust got lucky to be alive... I've heard of spring clocking a MF out of existance.
Old Mar 1, 2006 | 11:52 PM
teh CL's Avatar
mr. dust got lucky as hell...check for urself
Old Mar 2, 2006 | 01:22 PM
VaTECh_CL's Avatar
Let's go Hokies!
So the spring compressor i got won't work for the front springs...any ideas besides taking it to a shop??
Old Mar 2, 2006 | 01:32 PM
(Mid-Atlantic)
They look pretty :gheylaugh:
Old Mar 2, 2006 | 01:33 PM
(Mid-Atlantic)
Find a big fat mofo and have him stand on the spring, have someone else slide the shock in and bolt it, have a third big guy to hold the fat mofo down so he doesn't launch into existence
