spent 5 hours trying to install my
Old 09-19-2003, 08:04 PM
05 STi White/Gold
jamolie's Avatar
shift light. for some reason, it keeps blinking at odd times. it turns on at the right rpm, but it just goes on these occasional spasms. what could cause this? also, after doing that, my gas gauge doesn't move. is this a connection problem? I don't have time to look at it until tomorrow or sunday so any help would be appreciated. what fuse do you connect your indiglo gauges and shift light to? thanks!
Old 09-20-2003, 07:56 PM
05 STi White/Gold
jamolie's Avatar
can anyone help?
Old 09-21-2003, 04:34 AM
ENGAGE MY VTEC BABY!!!!!!
97Acura3.0CL's Avatar
are you sure you tapped it into the rpm signal wire?
i would tap the signal wire into the back of your guages just get a light power tester, and have the cluster hooked up and then rev the engine with the power on , the signal wire would be the one that would fade when you rev it, ie, get brighter/dim when reving
let me know if this helps, hit me up on aol im and send me some pics of it and maybe i can help you some more
aol im: jgiguere17
Old 09-21-2003, 02:50 PM
05 STi White/Gold
jamolie's Avatar
aol im: jgiguere17
i dont have a tester so i just did it trial and error. only one of the two blue wires will work right? it that's correct, then i got the right wire. the shift light comes on at the right rpm, but it just flashes at other weird times. dunno what the problem is. it seems like a connection problem, but i just re-checked all the connections.
cycdaniel
12-17-2019 10:58 AM
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
PortlandRL
09-14-2015 12:01 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
asahrts
09-04-2015 05:55 PM
Quick Reply: spent 5 hours trying to install my
