Speedo acting funny???
Old May 11, 2007 | 09:06 AM
nickbeee's Avatar
I have a 98 2.3CL (manual) with 205K miles. I love my car and it’s been great to me. The only non-maintenance items that went are exhaust and one rear caliper.
About a month ago while driving into NYC in traffic my speedometer starting acting twitchy and hopping around all over the place (up to the 140MPH gauge limit). When I got out of the Lincoln Tunnel I shut the car down and started back up and the problem went away. Now a month later it’s doing it every now and then.
Any ideas? I hope it’s not a sign of a major problem like a computer starting to go on me…
Thanks!
Old May 11, 2007 | 10:13 AM
Cocoa's Avatar
2600lb CL
When that happened to me, my alternator went out shortly after. But since it's been a month for you, I dont think it's it, but you might want to have it tested at your local autzone.
Old May 11, 2007 | 10:17 AM
Ezekiel25_17's Avatar
My friend's 94 accord with 170,000 miles on it had that speedo problem too. Might be costly... it cost him 350 dollars.
Hopes this can give you an assessment if you plan any repairs. Good luck.
Old May 11, 2007 | 11:13 AM
lasvegasgamer's Avatar
Speedo
No worries, it has nothing to do with the computer (well, I'm 99% sure since the same thing has happened to me)
It's either the speedo sensor or the speedometer itself. According to the tech I talked to it is usually the sensor, but in my case it was the actual speedo.
Old May 11, 2007 | 11:28 AM
SwervinCL's Avatar
Nom Nom Nom Nom
another Vegas member....
Old May 11, 2007 | 11:49 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Vehicle Speed Sensor
Old May 11, 2007 | 03:13 PM
nickbeee's Avatar
Good info guys! Where is that puppy (easy to get to?) and how much are they?
Old May 11, 2007 | 04:41 PM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
acuraoemparts.com
acuraautomotiveparts.org
Old May 11, 2007 | 06:07 PM
nickbeee's Avatar
is this it?
78410-S84-A01 SENSOR ASSY., SPEED (MT) 1998 CL 100.10 79.68
80 bucks,,, not too bad... Where is it on the engine / trans?
Old May 12, 2007 | 08:19 AM
nickbeee's Avatar
BTW if this helps trouble shoot…
I was using my cruise control last night on the highway (I never do, not sure why I decided to use it) and when the speedo acted up the CC cancelled out (similar to pressing the brake or clutch). Tells me it’s most lucky the sensor and not the actual speedo… sound right?
Old May 14, 2007 | 09:17 AM
(Mid-Atlantic)
Correct
Old May 14, 2007 | 01:53 PM
nickbeee's Avatar
cool,, where do I find this puppy? Is it out in the clear or underneath a bunch of crap?
Old May 14, 2007 | 11:54 PM
As a side note, if anyone ever does do a speedo repair, make sure you / or the repair shop documents it etc. Can cause real problems with the DMV (etc) if you don't.
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
Specmiata82
Sep 30, 2015 10:04 AM
ceb
ILX
Sep 27, 2015 10:56 AM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
Jpro
Sep 13, 2015 07:14 PM
