Specs: Rims are 19x8, 4x114.3, +51
Used set of (4) Japanese WORK "VS" Rims-
Imported, and professionally redrilled to 4x114 to fit a 94-02 Accord, and 4 lug Prelude. One of a kind.-
Tires are 235/35/ZR19
2 almost new Nitto Tires, other 2 should be replaced
Similar to Work VS XX, but have center cap for added security
Some scratches and scrapes, but easily repairable at any wheel shop. Not bent, no dents.
Something tells me they will fit our car.
i can't help it , im just so in love with WORK wheels.. any jdm wheel is cool 2 me 2 be honest i wouldnt
rock every set of jdms out there but theres only a slight few i wouldnt F with
Hey sup man,
That rim there is 8 inches in width, that is one big wide rim, and with that offset you might be rubbing against the outer fender. Meaning they will probably stick out and most plausibly fuck up the fenders. Especially with a drop. However, those are one nice set of rims. If they do fit they would look hot!!! If you want them that bad, hey you can always roll out the fenders.
-James
-James
Yeah but y'all notice that the ones in the link are 42-45mm offsets. This one here is 52mm. That surely will rub. I have 17x7 rims with a 225/45 tire and they are on the brink of rubbing. And I have a 38mm offset. The tires have about a quarter inch from hitting the control arms and about half an inch from rubbing on the fenders. I have to admit that they are comfortable though. And 99CL, gotta praise you for posting that link, instead of the cliche'd "use the search" and that's it scheme most do.
-James
-James
calrow
05-03-2017 11:21 PM
