SPC Front Camber Kit Issue
I bought a SPC front camber kit for my 99 Acura CL with a -1.5 to +1.5 degree adjustability. Btw the part # is 67125. Well I decided to get them installed today and the shop said that this camber kit did not fit, because the sliding plate is too big to fit the control arm. When I found this out I was very disapointed...so I called the manufacturer and they said they have an alternative sliding plate that is smaller which will fit my car. I just hope it fits when it arrives. Anybody ever had the same problem with their front ball joint camber kit installation? If so please share your experience.
I had the same problem i think... or it should be similiar...
http://www.acura-cl.com/forums/showt...36#post2413836
Just call the number... and they'll help u out.
Originally Posted by agranado
...weird. I have the same piece. I hope thats not the case when I get it installed...
1) Ball Joint: 67125
2) Top Plate: 67144
3) Slide Plate: 67342
Make sure you have these # before you bring it to a shop and install.
Sep 4, 2015 08:03 AM
nuldabz
Sep 3, 2015 05:49 PM
