some problems w/ indiglo gauges...
Old Mar 24, 2002 | 06:29 PM
SHYROCK7's Avatar
97 Acura L'Arc~en~CL
i finally got a day off from work and started the installation for the indiglo gauges. its not easy to do but aint that hard to do either....
but i ran into some problems... first, the gauges fitted in size but the holes for the 2 screws for each did not match up~! ok... so i decided not to screw in the gauges in place (the outter frame does hold all the gauges in place)
i dont know if it was a defect or if it was for a different model car...(i bought it from ebay from"procarpart.com" or something)
ok.... it does not look perfect but i thought it looked good enough
the temperature gauge came up to "normal" ok!
the fuel tank gauge is where it's supposed to be. ok!
the RPM gauge was normal as well. ok!
and as i was driving out of the driveway, the speedometer was not moving at all~!!! (the mileage was counting up as normal..)
does anyone know what i can do to fix the gauge for speedometer?? (someone toll me that it's just a fuse for the gauge but i'm not sure )
pleeeez help me~!!
Old Mar 24, 2002 | 07:15 PM
dcsquirm88's Avatar
You didn't take the needles off the gauge cluster did you?
If you did then thats probably why its not working.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
