Smelling gas coming from the engine
Old Aug 21, 2002 | 06:11 PM
CLShadee's Avatar
The Shadee Member
Tech question...
I went to Vegas on a "hot" weekend. It was at least in the 100's F. Well, with the AC blasting I started to smell gas in my car. The vent was set to "fresh air", in other words, air from out side. It got really bad to the point I was going to pass out. I went to an Acura dealership and the specialist told me that it's common in our year CLs and Integras. Apparently when it gets hot outside, the gasoline in the charcoal filter (purge valve and canister for emissions duty) doesn't evaporate the gas too well and so you get that smell. He says that there's nothing you can really do. This is just something our year CLs (maybe even our gen of CLs) didn't get fixed.
Just wanted to know if anyone has ever experienced this kind of thing and what was told to you...and if not and you do for the first time...at least you might now what's going on and ask your mechanic about it.
Old Aug 21, 2002 | 07:15 PM
niedejb's Avatar
Swaps? $3000 for 50HP? :(
Park on dry pavement and look for dripping between the front wheels.
Open the hood and see if you can actually see a leak.
Old Aug 22, 2002 | 01:25 PM
joeshmoe's Avatar
My Home Planet
Check you fuel rail.
If the dealer checked it out, they should have looked at this but just in case they screwed up.
Old Aug 26, 2002 | 03:29 AM
99'2.3CLever's Avatar
check your fuel hosings could be a crack where gas will leak
had similar problem with another car, just change the rubber hos
Old Aug 26, 2002 | 08:13 PM
clac225's Avatar
tlac356
the same thing happend to me, like 3 years ago when I bought my car, every once in a while when I had the AC on I smelt fuel, then it just went away, havent had a problem since.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
sockr1
Oct 1, 2015 01:31 AM
PortlandRL
Sep 14, 2015 12:01 PM
iCrap
Sep 11, 2015 06:21 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
