side mirror heaters?
Old Dec 27, 2007 | 08:37 PM
sporting's Avatar
Hi guys, just wondering if anyone has changed/replaced their side mirror heaters before? I think mine are not warm enough to sufficiently defog my side mirrors.
Does anyone know if I have to replace the whole side mirror with the housing or can I just replace the "heater" itself and not the housing or mirror? Thanks.
Old Dec 27, 2007 | 08:45 PM
AznX TL's Avatar
where is....
http://www.acuraautomotiveparts.org/...s=&view=normal
not too sure if its just the mirror and heater or the whole side mirror w/housing.
Old Dec 27, 2007 | 09:36 PM
Alperovich's Avatar
6spder
you should only need to replace the glass. It had the heater built onto it
Old Dec 27, 2007 | 09:39 PM
Alperovich's Avatar
6spder
its 21/24 from the link
Old Dec 27, 2007 | 10:53 PM
AznX TL's Avatar
where is....
what about the ones that say (heated)
Old Dec 27, 2007 | 11:19 PM
sporting's Avatar
I think that is the whole housing plus everything inside it.
I think I'll just get the mirror if that is the heated part.
Old Dec 28, 2007 | 12:58 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
That's the whole deal
Old Dec 28, 2007 | 01:37 PM
sporting's Avatar
Does anyone know if the 97-99 CL 2.x-3.0 have the same side mirrors?
I called Acura and they have different part #s. To me all the side mirrors look the same? What gives?
Old Dec 28, 2007 | 02:16 PM
Alperovich's Avatar
6spder
yes they are different. the 3.0 has heated mirrors. which entails it has different glass from the 2.x and it has a different wiring harness (to include extra wiring for the heater)
But the actual housing is the same. internal's will be different.
Old Dec 28, 2007 | 03:20 PM
sporting's Avatar
How about 97, 98 and 99 CL 3.0? Are they different or the same both inside and out?
Old Dec 28, 2007 | 04:57 PM
972.2's Avatar
should be the same
Old Dec 28, 2007 | 05:32 PM
sporting's Avatar
Has anyone ever taken out the side mirrors (not the housing)? Do I need any screw drivers or is it just popping out the mirror and popping in the new mirrors?
Old Dec 28, 2007 | 05:38 PM
AznX TL's Avatar
where is....
i've done it, but i dont have heated mirrors. all i did was stick a screw driver in and pry out the mirror, its held on by this little ball/joint in the middle of the mirror.
Old Dec 28, 2007 | 06:40 PM
Alperovich's Avatar
6spder
/\ heated mirror's are the same, only difference is tehre are 2 wires attached to the glass.
Old Dec 29, 2007 | 01:01 AM
(Mid-Atlantic)
rockyboy
Aug 4, 2024 10:35 AM
Type S Zero
Feb 17, 2016 02:37 PM
guitarplayer16
Nov 29, 2015 02:03 PM
sockr1
Oct 1, 2015 01:31 AM
