Should i buy this camber kit?
Ebay..
Im not about to drop $300+ on a camber kit. found these.. Theres also this:
Ebay #2
Or this one which sez it uses rubber bushings.. but who knows..
Im gunna get flamed for this, but i need to do this on the cheap(er) than $350 for a full kit.. I spend $350 for my tokico illuminas and $60 for neuspeed sports. now i have a saggy butt and its bugging me. Thnx
Ebay #2
do the washer trick for the rear.... and i hear people getting the ingalls kit. you coudln't find anything when u searched? The front shouldn't cost u more than $150.. and the washer trick should cost u less than $7
Wakeboard. For front and back? And can it go to 3degrees. Also is it the same one i was looking at? Thnx.
I searched and ive learned a lot. but other than the washer trick everything pple reccomend is damn expensive. And the washer trick wont help the fact that the control arm is rubbing the inner fender. I need to fix somehting because my back left is dropped about 3" and back right is dropped 2" so i need to replace Something..
lol man that must be a biotch.. if it makes ya feel better i had both rear control arms replaced when my shiz went in cause they were all messed up from rust and the heads of bolts would just fly right off
nuldabz
09-03-2015 05:49 PM
