Shock Sensor
Shock Sensor
Hey..whats up everyone...
i tried searchin but there was no real conclusion on the install...or mixed solutions..
Its in already both leds are working....the prob is that i have really mess with the car in order for it to go off. Even on the most sensitive setting.
the shock sensor has four wires coming out of the bottom...left to right: blue-white-black-red
used the blue(trigger) black(ground) and red(power)
was wondering if i use the white(warning) to connect with the blue or tap into another wire. used the 1st gen pinout and i think a8 is circled in green(white) but there is no description
it says M A S...guess thats the brand, i got if off c-c-c
i also have that problem that i sometimes lose the chirp because i lock it right away most likely cause there is movement as it locks. just wait a few second then lock it and it works.
well if someone can give me more insight and a solution...then i wont knock them so hard....j/k
