shaking from engine on driver side
Old Apr 14, 2004 | 01:38 PM
jholland's Avatar
Hey guys, I need some help. My engine is shaking a little bit when idle or in drive with the brakes on. It is not a consistent shaking/vibrating but it is more like a couple of jolts every couple of seconds. I have replaced all the plugs, air filter, oil, tryed fuel injector cleaner, and used super octane gas a couple of times. Could it be the fuel filter? or fuel pump?
I think I can change the fuel filter myself, but don't know about the fuel pump. Any help would be appreciated.
Old Apr 14, 2004 | 01:45 PM
CLpower's Avatar
teh Senior Instigator
a little shacking is normal, I know my car shakes. Also, FYI ONLY use 87 on the 3.0
Old Apr 14, 2004 | 01:47 PM
EPS CL's Avatar
SSM Accord V6 6 Spd
maybe the motor mounts need to be replaced?
Old Apr 14, 2004 | 01:54 PM
jholland's Avatar
The shaking I am experiencing is not normal.
I have had the car for over 2 year now. It use to be hard to tell if the car was started or not because it would be so quite. As for the motor mounts. Do you know where I would look to see whether or not they need to be replaced?
Old Apr 14, 2004 | 02:15 PM
SooDARK's Avatar
05' 350z 6spd.
you gotta jack it up or put it on a lift to see the mounts. Is it your engine actually moving? Or i it like a shaky idle?
Old Apr 14, 2004 | 02:29 PM
jholland's Avatar
It is more like a shaky idle. When I pop the hood to try an locate where it is coming from I can't see the engine shaking.
Old Apr 14, 2004 | 02:41 PM
Acura3.0CL's Avatar
DamnThisHobby'sExpensive!
my sisters accord is doin the same thing..shaking really bad when it idles...i think its the motormounts...
Old Apr 14, 2004 | 02:48 PM
jholland's Avatar
Does anyone have any scanned images showing how to change the motor mounts? If not can anyone tell me what it is I am looking for under the engine to see if it is in fact the motor mounts? Acura wants to charge me $95 an hour labor and minumim of 2 hours just to check it out.
Old Apr 14, 2004 | 03:32 PM
wilp99's Avatar
replace the plug wires. im sure that will take care of it. the posts get little hir sized holes in them and causes it to dicipate spark.
Old Apr 15, 2004 | 08:36 AM
jholland's Avatar
Uhmm, I think you may be on to something. I am going to buy new cables today and see if it solve the problem. Thanks.
Old Apr 15, 2004 | 01:56 PM
wilp99's Avatar
no prob
Old Apr 15, 2004 | 02:01 PM
jholland's Avatar
Hollycrap! They want $200 for those cables. I don't know why they are so expensive. Other car cables or only $40-$60.
Old Apr 15, 2004 | 02:29 PM
wilp99's Avatar
go to the atuopart store, instead of honda or get the ones for a 98-02 accord, thier obx and 10.3mm in size those are 50$ thats the ones i got. check my www.
Old Apr 15, 2004 | 02:39 PM
Slooo97CL's Avatar
Re: shaking from engine on driver side
if you apply the brakes and it shakes...thats warped rotors
idle shaking is normal especially when the engine is cold, do you have a 2.2/3 or 3.0? shaking idle probably more common in the 2.2/3's
or motor mounts..
Old Apr 15, 2004 | 02:59 PM
jholland's Avatar
It is doing it whether it is warm or cold.
I have a 97, 3.0
Old Apr 15, 2004 | 04:48 PM
Slooo97CL's Avatar
I have a 97, 3.0
get the idle adjusted, and get your brakes checked out
Old Apr 15, 2004 | 07:11 PM
jholland's Avatar
Dude, how can it have anything to do with my brakes? It does it with the car in park.
Old Apr 15, 2004 | 08:03 PM
Slooo97CL's Avatar
nevermind dickhead i read your post wrong.
Old Apr 16, 2004 | 09:26 AM
jholland's Avatar
Don't be calling me a dickhead. Misunderstanding no problem. Thanks for helping me out. It is more like a shaking from the engine every couple of seconds. I am curious about the motor mounts. I am going to be pissed if I change the ignition wires and it doesn't solve the problem. Thanks again for your help.
Does anyone know how to increase the idle speed? Maybe my car is idling too low. The car doesn't shake when it is moving.
Old Apr 16, 2004 | 01:49 PM
Duece's Avatar
LA`s Top CL
im thinking its your mounts bcuz i have the same problems but for me it can also be my flywheel
Old Apr 16, 2004 | 02:11 PM
jholland's Avatar
Does anyone discribe to me what the motor mounts look like and what I would be looking for? i.e. cracked, lose screws, etc. Thanks in advance.
Old Apr 16, 2004 | 02:18 PM
CLpower's Avatar
what does the car idle at?
Old Apr 16, 2004 | 02:20 PM
jholland's Avatar
About 500rpms
Old Apr 16, 2004 | 02:24 PM
CLpower's Avatar
yea, that's a little low, however that's where mine idles at sometimes now until I give it a little jab of gas then it goes to around 700-800 and all is normal.
Old Apr 16, 2004 | 02:27 PM
jholland's Avatar
Do you know how to increase it?
Old Apr 16, 2004 | 02:28 PM
jholland's Avatar
Maybe it is the cables. What are the symptoms when it is the motor mounts?
Old Apr 16, 2004 | 02:41 PM
Slooo97CL's Avatar
yeah sorry, i think the idle is low at 500rpm, when mine gets that low i get that stall out/vibration feeling..i just give it a little gas and its better, happens once in a while.
Old Apr 16, 2004 | 02:44 PM
jholland's Avatar
Yeah, its no problem when I give it a bit of gas. I am going to do a search on increasing the idle speed to see if I can find something. Thanks again.
Old Apr 16, 2004 | 02:52 PM
Slooo97CL's Avatar
i would bring it to acura or any honda/acura mechanic to adjust. i have a shitty chilton's repair guide and it has 2 symptoms to engine shaking while idling.
1) Check for loose, collapsed, or damaged engine or tranny mounts.
2) Check for loose or damaged engine covers or shields and secure or replace.
Old Apr 16, 2004 | 02:58 PM
jholland's Avatar
Thanks for all your help. I am going to get under the car and see if I can see anything. The problem is that it is intermittent. I took it to Acura and the f*cking motor didn't shake at all. Take it home and it starts shaking like crazy again.
Old Apr 16, 2004 | 03:11 PM
CLpower's Avatar
to see if it's the motor mount open the hood and try to stand on the engine as best you can and try shacking it. I seriously doubt it's your mounts
Old Apr 16, 2004 | 04:08 PM
wilp99's Avatar
i also doubt its the mounts. mounts would be worse at accelleration. change the wires and if that wasent the prob, im very sorry. u cannot change the idle. it has a set screw in the t/b.
u could make sure the timing is right on. as a car gets older the belts gets looser causing a retard of abour .5 deg. which is just enough to eat gas and run alittle rough. however i would change the plug wires first.
rockyboy
Aug 4, 2024 10:35 AM
01CLOwner
Oct 9, 2015 01:07 PM
sockr1
Oct 1, 2015 01:31 AM
hand123
Sep 10, 2015 09:27 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
