shaking
Car is Back
shaking
Im having problems with my car when im slowing down from high speeds my car starts to shake as im pressing on the break. Any ideas what this might be?
some things off the top of my head are
1. uneven rotors
2. worn brake pads
3. alignment
when you brake, theres the vibration from your suspension and braking system that is transfered to your steering wheel. With old cars like ours, theres really no way to stop the vibration besides replacing the whole setup.
1. uneven rotors
2. worn brake pads
3. alignment
Car is Back
1. uneven rotors
2. worn brake pads
3. alignment
1. uneven rotors
2. worn brake pads
3. alignment
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Warped rotors
alignment WILL NOT make a car shake, it will make a car pull and wear tires unevenly,
if it shakes when you brake you have warped rotors, if it shakes when you drive slow you have a separeted belt on one of your tires, if it shakes at highway speed you need balancing.
(Mid-Atlantic)
(Mid-Atlantic)
less n00bin more g00glin
Save yourself a hassle and measure your own rotor runout and save a trip to the mechanic. It should not exceed 7 thou in the absolute most extreme cases.
Cheers
Cheers
defently rotors. i had the same promblems and i redid my rotors but you should of done your brakes as well because what happends is that your brakes have the same tred marks of the old rotors and its going to pass it on to ur new rotors and you might still get some brakeing issues or a lil shake. i did this mistake. i only resurficed my rotors and mechanics told me that i had to do the brakes as well becuz of that reason. its your choice and when it comes down to it, its all about $$$$
*(-_-)*
depends if they got dropped between the point that they left the assembly line to the time you got them.... or possibly a flaw during manufacturing, but most likely it would be a no for turning new ones.
vpasla1
09-17-2016 07:24 PM
