Shaking?
Shaking?
I get some shaking of the steering ive noticed when im going about 30-50 but above that its ok and not much
anyone have the problem or know what it is? i thought maybe its some old mounts giving me the shakes
also after my tranny swap and replacement ive notice a whie only i park and neutral anyone know what this is? it doesnt do it in drive or in reverse just in park and neutral and not all the time
ive been told my idler pulley bearing is going out or ready to go out, how much would this cost to replace it?
I've got a similar problem on my 99 3.0. You know when you put it in d4 and only go 40 mph how it shakes since it's revving so low and struggling? Well it does that except it does it when I'm coasting. like around 30 I'll be in d3 an I'll just completely let off the gas and coast and the car will kind of shake, but when I press teh gass a little bit the shaking goes away. sounds like we have similar problems.
teh Senior Instigator
Originally Posted by BEETROOT
the shaking probably means you need an alignment
more likely means his wheels need to be balanced, an alignment would have you pulling to one side.
Originally Posted by 97Acura3.0CL
my wheel weights are taped down with duct tape to ensure the stay in place
so i dont know
any more ideas?
so i dont know
any more ideas?
like where RJ?
could the tire be off, like the belts be off balence? i mean when i turn its ok and it doesnt shake, but only like i said around 30-50 and then its goes away after accelerating
Originally Posted by liloj
are your tires real worn? or fairly new?
really new only about a couple of month since the car sat when the tranny went out so only about 3 months worth on new tires
btw they are 17" 225/45/17 z rated michelon wynstars
vpasla1
09-17-2016 07:24 PM
