seat wont lock
7th Gear
seat wont lock
the other day i was vaccuming out my 98 cl. and i flipped the switch to move the seat up and when i went to push the seat back it wouldnt lock into any place. i got down to look at what might be the problem and there is a rail with these holes in it for the seat to lock, but the piece that is supposed to go into one of those holes isnt working. i was wondering if anyone has had this problem before and if there was a way for me to fix it without sending it to the shop........again
![Mad Fawk](https://acurazine.com/forums/images/smilies/madfawk.gif)
SSM Accord V6 6 Spd
i had the same problem. my dickhead friend had a quarter drop from his pocket and got stuck in the rail. just use a magnet, or some superglue on a stick to get rid of it.
hope this helps.
hope this helps.
I've been marked.
12mm Socket Wrench and take out the 4 bolts, clean under your seat, clean ur rails, put ur seat back in, fixed in 10-15 minutes.
Compared to looking under a nasty (most of the time) sticky place for something you don't know whats there
i had the same problem.. i found a quarter wedged in there and it was stuck.. got it out with a screwdriver.. (took me 15 minutes.. ghey..) but sometimes it still gets stuck without anything stuck.. so now i just push it back as hard as i can and it usually clicks in...
Originally posted by legendaryCL98
i had the same problem.. i found a quarter wedged in there and it was stuck.. got it out with a screwdriver.. (took me 15 minutes.. ghey..) but sometimes it still gets stuck without anything in there.. so now i just push it back as hard as i can and it usually clicks in...
oops.. i just quoted myself.. im such a nub..
MrHeeltoe
20
02-23-2023 01:54 PM
soupi
14
11-15-2015 11:15 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
