Seaform 2.3...
Old Mar 21, 2008 | 06:16 PM
fromztosuv's Avatar
Seaform 2.3...
I've search the forum but i seem to find the DIY for the 2.3 CL. I know the basis of it is the same but where is the vacuum line to suck the seaform for the 2.3?
Sorry if its a re-post but like I said, I search to no avail...
Old Mar 21, 2008 | 07:49 PM
xdaex's Avatar
278
From the booster line(I think) I have diy from h-tech...let me check
Old Mar 21, 2008 | 08:12 PM
xdaex's Avatar
278
http://www.diyimports.com/seafoamprint.html
Different car, same concept.
Old Mar 21, 2008 | 10:35 PM
fromztosuv's Avatar
Which one... Do I disconnect the PCV & suck Seafoam throught PCV or disconnect the line to the PCV & only suck Seafoam through that line going to the intake?
Old Mar 21, 2008 | 11:46 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
We do have a diy, it's for a 3.0 but it's pretty much the same thing
Old Mar 22, 2008 | 01:01 AM
G22_Powered_YA1's Avatar
either way would work, ive always just sucked it through the PCV valve itself since the hose is such a pain to get off
Old Mar 22, 2008 | 01:12 AM
AznX TL's Avatar
where is....
yeah, i did this too.
i put 1/3 thru pcv, 1/3 into crank case and 1/3 into gas tank.
Old Mar 22, 2008 | 10:30 AM
Dan3952's Avatar
Yesterday I poured it into the PCV line and air intake (after removing the filter assembly). Half the can also went in the gas tank at my last fill up. This time I observed that the liquid sits by the EGR valve waiting to be drawn through the system when you drive it hard, hence the smoke while driving. I don't think you have to use the whole can even.
Old Mar 22, 2008 | 03:49 PM
fromztosuv's Avatar
Ok... Just completed the Seafoam (1/3 in intake, 1/3 in crankcase & 1/3 in tank), she appears to idles smoother. Man it seemed as if a cloud from the heavens descended upon my CL!
(This picture does no justice)
Old Mar 22, 2008 | 04:06 PM
AznX TL's Avatar
where is....
haha, seafoaming is fun, especially flooring it and leaving a huge cloud behind........but make sure you do this infront of your house or something.......don't need to be james bond and blind everyone else
Old Mar 22, 2008 | 05:01 PM
Dicorp's Avatar
i'm still debating if i should do this. as bad as engine gunk is, it keeps ur seals together. I already had an oil leak on my h22, i dont need another.
Old Mar 22, 2008 | 05:07 PM
I dunno about the H motors but I seafoamed my F22 at around 130k for the first time and nothing broke or leaked, ive still got some consumption, but that was always there....... stupid lead-footed redline addiction
but ive started to use Motul EngineClean to clean it out every other oil change, and it works great, im sure my fuel system is in need of a good cleaning though
Old Mar 22, 2008 | 05:14 PM
Dicorp's Avatar
i only have 81K on my h22, but its 13 years old. i dunno if i should fuck with it or just leave it. if this is gonna help my gas milage, i'll consider it
Old Mar 22, 2008 | 05:51 PM
(Mid-Atlantic)
Can't wait to do this, have had the can sitting for like 6 months
Old Mar 22, 2008 | 05:55 PM
saiko_cl_duck's Avatar
me too, just haven't gotten around to it. Damn we're lazy Chris.
Old Mar 22, 2008 | 08:27 PM
(Mid-Atlantic)
no.... busy yes, lazy no
Old Mar 24, 2008 | 02:00 AM
Dan3952's Avatar
I don't put Seafoam or even STP engine flush in the oil for that reason... just the intake
Overfilling with Mobil 1 last fall caused the worst leak I've had (the rear main), but after Seafoaming for the second time and filling with the Valvoline Synthetic Max Life 10W30 I don't see a drop underneath anymore. Go figure.
Gigolo
Nov 20, 2012 11:33 PM
04_aztl
Jun 20, 2010 01:50 AM
wdhart3
Sep 6, 2009 01:09 AM
555acuratl
May 19, 2008 11:24 PM
omg_its_the_2.3
Dec 30, 2007 03:37 PM
