lost screw
Old Mar 19, 2008 | 12:34 PM
tman89544's Avatar
lost screw
So i went to try to remove my stock head unit but i ran into a problem that i know i should know. How do you get the screw out of the drivers side by the steering wheel?
Old Mar 19, 2008 | 01:20 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Is this on the headunit itself or the console? If it's the console, you have to remove the cowling from under the steering wheel, and then you should see the screws
Old Mar 19, 2008 | 07:29 PM
tman89544's Avatar
Uhh i know the screws are there, i just can't remember where exacly it was. Last time i did it i did not have to remove the steering wheel at all.
Old Mar 19, 2008 | 07:37 PM
(Mid-Atlantic)
You don't need to remove the steering wheel, just the plastic piece underneath
Old Mar 22, 2008 | 02:51 PM
tman89544's Avatar
I never had to do that in the past, but i might just do that so i dont screw anything else up.
Old Mar 24, 2008 | 02:09 PM
99CL's Avatar
blah blah blah
If you have a 98-99 (dash will be different for 97). You'll have to remove the armrest. remove the cupholder to remove screws. Open armrest and remove screws. The whole section should come up. Then there's two screws that holds the center wood piece. Once that is removed. Pull out ash tray and remove screw behind there. You should be able to pop off that trim. Of course unplug everything on it. After that, you should be able to see the screw holding the radio.
HOpe that helps. if not do a search...
Old Mar 24, 2008 | 03:40 PM
tman89544's Avatar
Yeah i've done it before but for some reason this time it all didn't come right out.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
