'Rust' on Rotors
Old Jun 23, 2008 | 11:29 PM
ZeroCL's Avatar
W WHIP.
'Rust' on Rotors
I'll be painting my calipers here shortly and was trying to figure out if you guys know of anything that'll take rust off my rotors. Its not exactly on the rotor but rather on the ledge between the rotor and the wheel. I can take a pic of it tomorrow but most of you hopefully know what im talking about. They're brand new rotors so im kinda pissed they have rust on them already. any ideas guys? thanks.
Old Jun 23, 2008 | 11:32 PM
AznX TL's Avatar
where is....
its pretty normal.
Old Jun 23, 2008 | 11:34 PM
ZeroCL's Avatar
W WHIP.
I understand that. I just figured since I'll already be in there, might as well try?
Old Jun 23, 2008 | 11:36 PM
AznX TL's Avatar
where is....
take steel wool to it. i can't remember if brake cleaner takes it off or makes it rust
Old Jun 23, 2008 | 11:57 PM
ZeroCL's Avatar
W WHIP.
I'll try the steel wool. and i searched but couldnt find what i needed. whats a good product to use to clean the calipers. I have engine degreaser but that leaves behind a residue. thanks
Old Jun 23, 2008 | 11:59 PM
shnee's Avatar
Land of Pleasant Living
try rust remover and steel brush?
Old Jun 24, 2008 | 08:34 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
they also make brake disk cleaner, I have a can in my garage
Old Jun 24, 2008 | 10:55 AM
dragon084's Avatar
1999 CL3.0
its gonna be a pain in the ass.
Once it is clean, it will probably get dirty really quick.
My rotors are disgusting..
Old Jun 24, 2008 | 11:44 AM
DaInFaMMuS1's Avatar
just had my rotors done, i'll ask my mechanic what he used. Then again theyre resurfaced lol.
Old Jun 24, 2008 | 11:53 AM
swiftt5389's Avatar
..could never believe that....
Old Jun 24, 2008 | 12:01 PM
(Mid-Atlantic)
different shelf though
Old Jun 24, 2008 | 12:07 PM
Dicorp's Avatar
last i checked rotors were for stopping, not for looks. but seriously, its normal...anything you do, it will come back very soon. not worth the time to clean.
Old Jun 24, 2008 | 01:09 PM
shnee's Avatar
i may tackle this soon.. im going to do the rust remover and steel brush, and then use this primer stuff that covers it and prevents rust from coming back
Old Jun 24, 2008 | 01:35 PM
jfkhan's Avatar
Jhatt from Ludhianna
or you could buy new rotors with some nickel cadmium coating and it will never look rusty ...btw that what I got when I replaced my rotors....
my 2cents
Old Jun 24, 2008 | 01:53 PM
LocoCoco's Avatar
Noob
Ever change rotors in a drizzle? Laying flat on the ground, literally within minutes each raindrop will form a little rust spot. Bare metal rusts faster than you'd imagine.
As for rust paint on the edge of the rotor (I'm guessing that's what you're talking about?), put a wire brush on a drill then try POR 15.
The stuff uses moisture to cure, to the point where the company warns that even one drop of sweat dripping into the can will ruin the whole thing. The good thing about that is that it's recommended that you paint over rust rather than reduce it to bare metal. We use this on Jeep frames and tubs and I've personally seen them go 10 years on a 20 year old Jeep with no rust coming through.
The only issue I can think of to look into is how well it handles high temperatures. That, I have no idea. Well, that, and it gets expensive if you use a lot of it. Here it's about $50/quart.
LC.
Old Jun 25, 2008 | 04:00 PM
XxAtTheGatesxX's Avatar
Guitarded
I sanded mine forever before I painted em. You can try that.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
lanechanger
Oct 13, 2015 10:56 AM
polish_pat
Sep 30, 2015 12:22 PM
