road noise
i like orange juice
road noise
ive had a lot more road noise than usual(on rough and smooth roads)....anyone else get it? its at low speeds and high speeds also, ive checked my windows, sunroof, etc..everything is tight....is this natural? anything wearing down i should be aware of, ive got 140k miles(est.).....i guess i should take the carpet out and throw some dynomat underneath? any other solutions?
and tire noise is out of the question, cause ive had someone drive by me and its not loud at all...only basically wind noise....
-rj
-rj
check the seal in the doors. or the little window alignment plastic piece if the window is on the outside of it that is deffinatly ur problem. also try checking ur trunk seal. that could also trap air into the cab.
i like orange juice
Originally Posted by wilp99
little window alignment plastic piece if the window is on the outside of it that is deffinatly ur problem. .
exactly where is this at?
ENGAGE MY VTEC BABY!!!!!!
ever think about hearing it through the firewall? maybe your selas are old in the doors and need replacing, remember lilo, big baller wheels do bring road noise with them
![Mantis](https://acurazine.com/forums/images/smilies/mantis.gif)
i like orange juice
its not from the tires...my old 19s made a ton..so i can tell the sound diffrence..this is more wind like..and joe, i checked my firewall..only thing really is the hole for the power cable to my system..but thats sealed tight...
this is annoying...ohh well....
lil hoes on the door and window sill can do that...just replace the door sill first...its doesnt cost that much and pretty simple...dynomat ur whole floor, thats gonna weight down ur car a lot. its all that bass that cause ur shit wear out.
Try a rubberized undercoating for sound deadening, although I'm not convinced of the usefulness of this material for keeping rust off the undercarriage (I rented a lift and had a look.. last year's job had half the material peeling off)
-rj
-rj
http://pg.photos.yahoo.com/ph/wilp99...c0.jpg&.src=ph
make sure its pushed all the way into the track. u check it with the window down. and make sure the window isnt goin outside of it. and check the one on the passenger side too. if thats not it ...i dont know.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
