RIMS offset question
Old Apr 29, 2004 | 05:22 PM
DanMan1464's Avatar
Autobot
would a 4x114.3 with a +40 offset fit on the 1st gen no problem?
I need new rims, and I dont' want to buy them online without having them fit on properly....
Looking into Motegi MR7....going cheap cuz I'm not a bank
Old Apr 29, 2004 | 05:35 PM
lomeli3.0CL's Avatar
i just ordered 19x8 with a +40 offset...i hope they fit fine
Old Apr 29, 2004 | 06:12 PM
ju5tchi11in's Avatar
roomate has a CL too
the motegi's are really heavy I was thinking about getting those first but then I saw how much they weigh... waht is it 27lbs per rim? or something that is way to much.
what size rims are you getting? 18x7.5 should use around a +42-45mm if I recall correctly. Im not sure how +40mm will fit... it might not... actually.
Old Apr 29, 2004 | 06:15 PM
III's Avatar
III
prototype
poke-style! haha
Old Apr 29, 2004 | 06:17 PM
Originally posted by III
poke-style! haha
I don't get it... poke-style what is that?
Old Apr 29, 2004 | 11:18 PM
DanMan1464's Avatar
Autobot
so 17" rims with +40 offset won't work? -_-
I don't want to get 18's, cuz the price jumps from 17" to 18"...
17" rims are cheap, so I want those....so find offset +42 to +48? Those are the ones that fit right?
What rims have that? Can you name some nice looking, cheap rims that fit? I'm open for anything but stock.
Old Apr 29, 2004 | 11:31 PM
baka_t's Avatar
The movement has started
+42,+45 is optimal. 40 and over 45 will cause problems.
Old Apr 30, 2004 | 12:06 AM
VXCL's Avatar
AWD Torque Monster
Offset is actually different depending upon the width of the rim.
a 17x7 with 40mm is not the same as a 17x7.5 with 40mm. just like a 18x7.5 and 18x8 would be different. The wider the rim the more will be inside the wheel well and more will stick out if the offset is the same. it will be about 6mm more in each direction. Im debating wheter or not to cancel my order of 17x7.5 40mm and special order 17x7 40mm. they would be lighter also
What is the stock offset on the 16x6s? +44???
Old Apr 30, 2004 | 12:15 AM
VXCL's Avatar
AWD Torque Monster
Oh and lets not forget about backspace. This varies between rims so without knowing that the width vs offset calculations are not gauranteed to be true. Usually manufactures keep this in mind when they list applications, but i would find out.
Old Apr 30, 2004 | 12:24 AM
VXCL's Avatar
AWD Torque Monster
wait i read something wrong. ignore that
Old Apr 30, 2004 | 12:48 AM
my bad the ones i ordered are 19x7.5 with a +40 offset...so they should be cool...
Old Apr 30, 2004 | 02:02 AM
DanMan1464's Avatar
Autobot
wait....confused here!
17x7 40mm offset will be fine theN? o.O I'm dying of confusion
Old Apr 30, 2004 | 02:59 AM
nippon_wa's Avatar
nippon_wa 2.0
get 19"s...
19x8 42offset
is the one that i ordered..
and.. i'm still waiting for rims!!
Old Apr 30, 2004 | 03:01 AM
baka_t's Avatar
Dan, you want to order at least 42 offset or more with 17's.
Old Apr 30, 2004 | 03:08 AM
DanMan1464's Avatar
Autobot
damn....well nippon...i'd get 19" but they are $$$$$
I'm young, only senior in HS.....I wanna get cheap rims, and Motegi MR7's look nice, cheap, but the OFFSET ALKFJLGDA
Are there MR7's with 42 offset? could I find any?
Old Apr 30, 2004 | 03:10 AM
baka_t's Avatar
They prolly come in any offset you need. usually, they come in different offsets just have to ask.
Old Apr 30, 2004 | 03:13 AM
DanMan1464's Avatar
Autobot
what about 18"?
18x7.5 @ 45 offset....that?
liloj's Avatar
i like orange juice
i still dont know the offset to mine.....all i know is the 19x8 part.....
Old Apr 30, 2004 | 03:16 AM
DanMan1464's Avatar
Autobot
lol
Old Apr 30, 2004 | 03:32 AM
baka_t's Avatar
what about 18"?
I, personally have 18x7.5 +44 offset. Had a little problems with my car real low but I raised it up a bit and no problems to this date.
Old Apr 30, 2004 | 03:35 AM
DanMan1464's Avatar
Autobot
ah.....i have an eibach pro-kit drop....so i shouldn't have that car real low problem right?
what series tires do you have? ***/40/18?
DanMan1464's Avatar
Autobot
oops:
I was also thinking of getting 205/45/18 or 215/45/18 tires....good?bad?
Old Apr 30, 2004 | 04:32 AM
baka_t's Avatar
225/40/18 Only went with that tire size because the tires are rated to support the heavyness of the car. This is my drop currently with 18"s. Its lowered around 2.75"-3" Personally, I'd get 225/40 with 18"s
Old Apr 30, 2004 | 04:39 AM
III's Avatar
III
prototype
first time i seen your car baka..... lookin good
Old Apr 30, 2004 | 07:33 AM
red99cl2.3's Avatar
who got the best deal?
i have 18's with 40+ offset and it looks good i rubbed in the back with people though
Old Apr 30, 2004 | 11:06 AM
DanMan1464's Avatar
Autobot
Whaht kind of drop do you have?
Old Apr 30, 2004 | 12:23 PM
baka_t's Avatar
Thanks man. Can't wait till I put my kit on.
rseb4agze
May 3, 2016 07:41 AM
funkbro2
Nov 17, 2015 10:23 PM
datadr
Sep 12, 2015 09:12 PM
nuldabz
Sep 3, 2015 05:49 PM
bailey24
Aug 31, 2015 05:38 PM
