reverse/indiglo
1SlowCL
reverse/indiglo
Sup guys...I have a question to ask...will a 97 Accord Reverse or Indiglo gauges work in our 97 CLs without any modifications to do? Thanks...aight....
1SlowCL
info...
sup woodsdaddy...thanks for that info...
Do you have it installed in your car? If you do, can you please give me instructions on how to put it on? If you don't mind only..aight man..
Everybody Wang Chung
first you need to take off the black cover that goes around the gauges. To do this you take out the 2 screws above the cluster, then there are 2 more screws behind the cruise and dimmer buttons. You need to pry these out to get to the screws. then you should be able to pull the black cover out. I can't remember how to get the cluster its self out, there should be some screws there. I don't remember it being hard to get out. Then you should slide the wheel down as far as it goes. There are 3 plugs I believe on the back of the cluster that you must pull off. Then pull it out. You will need to remove the 2 screws to get the metal brackets off the top of the cluster. That is really about it, remember to take the bulbs out, they are on the back side. The plastic cover will just pop off and so will the black part over the gauges. Be careful of the needles, they break easily. Slide your new gauges over the old ones and use the screws on there to secure them. Then just put it back together. Oh and you have to take the end off of the milage reset button, just pull it off. good luck.
1SlowCL
oh by the way man...do you know anyone here that has a Wings West Type W rear lip installed in their 97-99 CL? I would love to contact them and ask some questions about it. aight man...
I can't think of anyone that has it, I don't think it is a direct fit. You will have to get some custom work done. You might want to post a new thread about it, or try a search.
1SlowCL
black97clonbags...sup man...if you don't mind can you post a or send me a picture of your indiglo gauges at kits5254@hotmail.com
Apprciate it man...aight...
