reprogramming
Originally posted by Lishbone:
<STRONG>How or where can i find intructions to reprogram my keys?</STRONG>
1. Turn the ignition switch on (II on the ignition)
2. W/in 1-4sec, push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit. (Just at the steering wheel is fine)
3. W/in 1-4sec, turn the ignition switch off
4. W/in 1-4sec, turn the ignition switch on(II)
5. W/in 1-4, push the transmitter lock or unlock button w/ the transmitter aimed at the receiver again.
6. W/in 1-4sec, turn the ign. switch off
7. W/in 4sec, turn the ignition switch On(II)
8. w/in 1-4sec, push the transmitter lock or unlock again.
9. w/in 4 sec, turn the ign off
10. w/in 4 sec, turn the ign ON
11. W/in 1-4, push the transmitter again
12. Confirm you can hear the sound of the door actuators. W/in 1-4sec, push the trans lock or unlock button again.
13. W/in 10sec, aim the transmitters (up to three) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch off, and pull out the key.
15. Confirm proper operation with the new codes
hope that helps you all out
will the remotes from 2002 acura work on a 1998? They new remotes are so much smaller and nicer looking with the emblem on it.. love to switch my brothers to mine... wonder if it can be done?!
Originally posted by Casper98CL:
<STRONG>will the remotes from 2002 acura work on a 1998? They new remotes are so much smaller and nicer looking with the emblem on it.. love to switch my brothers to mine... wonder if it can be done?!</STRONG>
OUTRAGEOUS CL TYPE S
2G CL Transmission Recall Q & A
Feb 24, 2004 06:32 PM
Caddy©
Feb 7, 2003 08:44 AM
