Replacing rear caliper…
Old Feb 27, 2007 | 10:28 AM
nickbeee's Avatar
OK so I found my brake fluid leak on my rear caliper. Is there anything funky I’m going to need to swap this out? How is the brake cable attached?
Thanks guys!
Old Feb 27, 2007 | 10:45 AM
Cocoa's Avatar
2600lb CL
All I can think about is needing a clamp to squeeze the piston back in.
Old Feb 27, 2007 | 03:48 PM
acuratl_2nr's Avatar
might need to bleed the brakes too...
Old Feb 27, 2007 | 04:01 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
brakes will def need bled after changing a caliper
Old Feb 27, 2007 | 05:12 PM
nickbeee's Avatar
I figured I was going to need to bleed. It's the rear passenger that is being swapped. Will I have to bleed all 4 calipers or just that one?
thanks!
Old Feb 27, 2007 | 05:27 PM
nickbeee's Avatar
Is there anything special about removing the brake cable from the rear calipers?
Old Feb 27, 2007 | 06:28 PM
TheBatmobile's Avatar
I got a question, are there any after market calipers for our car? I'm looking at getting Rotora slotted rotors but that of course doesn't include new calipers which I need, so how do i find some nice ones to go with the slotted rotors?
Old Feb 27, 2007 | 09:22 PM
(Mid-Atlantic)
There are no am calipers for our cars
Old Feb 27, 2007 | 09:40 PM
so then it's either BBK or buy new stock calipers and paint them? Man I don't want to have to do that.
Old Feb 27, 2007 | 10:29 PM
spiderman3098's Avatar
cant u change the calipers from a legend gs with the 2 pistons if ur gonna buy new ones mite as well upgrade them a lil. sayin u have a 3.0 it should be a pretty easy upgrade and a lil better stopping power cause the force is more evenly spread out over the rotors.
Old Feb 28, 2007 | 02:06 AM
yeah you're right!! So I can buy some cool slotted AM rotorsmade for the prelude and match them with the calipers for the Legend and that would work, right? If so I might be doing that very shortly!! What's the size difference between the prelude and the 98 3.0 rotors?
Old Feb 28, 2007 | 08:42 AM
(Mid-Atlantic)
Just clean your calipers and paint them, it's a $30 fix
Old Feb 28, 2007 | 08:49 AM
nickbeee's Avatar
Hey Guys!
Still wondering how the brake cable attaches to the rear caliper. And if any special tools are needed.
thanks!
Old Feb 28, 2007 | 11:31 AM
yeah I know, but I'd like to upgrade them also. So I might go the legend/prelude route. Has anyone else done this? I know it can be done I just haven't heard any stories of it being done.
Old Feb 28, 2007 | 12:17 PM
(Mid-Atlantic)
You haven't read much then, or SEARCHED many people have done it
Old Feb 28, 2007 | 12:36 PM
HAHA
Honestly NO I haven't!! HAHA!! I'm gonna though!!
Old Feb 28, 2007 | 12:52 PM
(Mid-Atlantic)
Old Feb 28, 2007 | 02:52 PM
aye blackack did somebody redo der interior in Louis vuitton? or what da fuck is up wit dat pic. lol
and prelude rotors are bigger which means better lol dats all u need to know.
Old Feb 28, 2007 | 03:18 PM
(Mid-Atlantic)
a long time ago, someone in my thread in the pics forum made me bring this av out of retirement
OK so I've done my research and I've learned that the stock size for the 3.0 front rotors is 11.1in which is the same size as the prelude rotors. I got that info directly from the Acura website and the rotor is 25mm thick(1.0inches) which means it should have a 25T bracket not the 23T. So then I don't need prelude rotors and I don't need a new bracket all I'll need is the Legend dual piston calipers from the 93-95 GS. Now when it comes to brake pads I'm assuming Legend brake pads are needed to match the calipers?
So I'd run a setup like this
1. Rotora 3.0CL Slotted rotors f&r
2. 93-95 GS Legend Dual Piston Calipers in the front at least
3. brake pads for ?
4. Black hi-temp paint to make the calipers damn sexy!!
Are the calipers on the Legend GS dual piston in the rear also or just the front?
Here's some info I found about the Brake system on the 3.0 /2.3CL
Braking System .
Front Discs (3.0CL) Ventilated, 11.1 in (282 mm) diameter, 1.0 in (25 mm) rotor thickness
(2.3CL) Ventilated, 10.2 in (260 mm) diameter, 0.9 in (23 mm) rotor thickness
Rear Discs (3.0CL) Solid, 10.2 in (260 mm) diameter, 0.39 in (10 mm) rotor thickness
(2.3CL) Solid, 10.2 in (260 mm) diameter, 0.4 in (10 mm) rotor thickness
Old Feb 28, 2007 | 03:55 PM
(Mid-Atlantic)
yes, if you put legend calipers, you want legend pads
Old Feb 28, 2007 | 09:06 PM
arent the legend and cl pads the same?? from my past readings of other posts i think they are
Old Feb 28, 2007 | 09:10 PM
I thought I read they were the same size, but one guy said the edges were different or something, but yeah they probably are. Thanks for reminding me. So really all i need are calipers. Does anyone know if the rear calipers on the Legend are dual piston?
Old Feb 28, 2007 | 10:00 PM
teh CL's Avatar
ya might as well go with the legend pads, not like its gonna break your wallet either way..
and im one of the fuckers that have done the prelude rotor/ legend dual piston caliper upgrade + the hub over rotor conversion, but hopefully ur lucky and have a 98+ CL so that you dont have to worry bout it
Old Mar 1, 2007 | 12:26 AM
yeah all I need are calipers and brake pads but prolly not even brake pads. So I can go and buy the calipers at like advanced auto parts or something? Then they charge me some core price and then I give them back my 3.0CL calipers and I get my $$ back for the core charge?
Old Mar 1, 2007 | 08:20 AM
(Mid-Atlantic)
You will need legend pads
Old Mar 1, 2007 | 09:58 AM
nickbeee's Avatar
Thanks for hi-jacking my thread guys
But I still am looking for an answer on if I need anything special to remove the brake cable on the rear caliper.
thanks!
Old Mar 1, 2007 | 01:58 PM
SwervinCL's Avatar
Nom Nom Nom Nom
Noob Guide you noob......
Old Mar 1, 2007 | 02:12 PM
(Mid-Atlantic)
Old Mar 1, 2007 | 05:26 PM
teh CL's Avatar
thanks!
sorry bout the ..but no you dont need no special tool to take off the brake cable
Old Mar 2, 2007 | 10:30 AM
nickbeee's Avatar
Thanks Silver!!!!!
mada51589
Jan 9, 2025 04:40 PM
cobra10363
Jul 23, 2024 04:13 PM
wilztlxs
Dec 1, 2015 09:16 AM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
Ny1718
Sep 11, 2015 09:21 AM
