replacing a bulb
Old May 8, 2007 | 08:00 PM
drew11588's Avatar
replacing a bulb
if i wanna replace a lower parking bulb in the turn signal thing, do i need to take out the whole housing?
Old May 8, 2007 | 08:02 PM
CLpwner's Avatar
Mmmm...
Start searching bro...
Yes, it is much easier to access... there is one phillips head that you take out... its on the inside... you should see a little hole
Old May 8, 2007 | 08:04 PM
drew11588's Avatar
i tried removing the corner but nothing happened when i shoved my phillips in the plastic hole and turned...
Old May 8, 2007 | 08:06 PM
CLpwner's Avatar
Mmmm...
Nothin happened as in you were stripping the screw or nothing happened as in it wouldnt turn...
If it's the latter then push harder and grow muscles... if the first...
Old May 8, 2007 | 08:07 PM
drew11588's Avatar
couldnt tell which... i guess ill try again after i study for my ap calc exam
Old May 8, 2007 | 10:17 PM
subbuzz's Avatar
07 tl-s in
jk i had to, but yes get a long phillips and feel around.i push the len's in a bit before i take them out.sometimes it's a bitch but trust us it's in there.your gonna also have a spring and a clip might pop out...........
Old May 8, 2007 | 10:19 PM
subbuzz's Avatar
07 tl-s in
jk i had to, but yes get a long phillips and feel around.i push the len's in a tiny bit before i unscrew.sometimes it's a bitch but trust us it's in there.your gonna also have a spring and a clip might pop out...........
Old May 8, 2007 | 10:57 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
it's one screw, search next time there's a diy in the diy/faq forum.
Old May 9, 2007 | 01:02 AM
drew11588's Avatar
yea i read the diy's but it wasnt working for me. turns out i was going in with the phillips at a bad angle anyway i guess the bulb isnt the problem cause after i switched it, it still doesnt work... could it be the socket? and its probably not the fuse cause all the other lights work
Old May 9, 2007 | 08:35 AM
(Mid-Atlantic)
Sounds like a loose wire or the socket fo sho
oo7spy
Jun 19, 2023 12:48 AM
pplcrew
Jan 30, 2021 08:59 AM
acuraST
Sep 17, 2015 02:31 AM
brjones9
Sep 3, 2015 07:30 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
