Removing the alternator from a 3.0
Old Aug 21, 2004 | 08:51 PM
CL-'s Avatar
CL-
Three - Point - OH
Anyone know how.. or a how to link
or any advice.. i did remove all the bolts and stuff but i can get it out..
help.
Old Aug 21, 2004 | 10:55 PM
Cocoa's Avatar
2600lb CL
wiggle it through by the radiator. that's what i did, it's a tight fit, but it can be done.
Old Aug 22, 2004 | 12:27 AM
CLver's Avatar
It helps if you remove the radiator bolts to give you some extra room.
Old Aug 22, 2004 | 01:07 AM
CL-'s Avatar
CL-
Three - Point - OH
yeah i was thinking of that.. but i wanted to remove the left hand fan on the radiator.. will that help?
thanks
Old Aug 22, 2004 | 04:42 AM
rayman1031's Avatar
i did this not too long ago. look up dustbuster4's profile and in his signature should be a link with the scanned instructions. in short, you remove the fan, unscrew everything, take off belt and you're done.
Old Aug 22, 2004 | 09:48 AM
Hobo's Avatar
Flap.
ok ok, ive done thjs literally 6 times
un bolt the passenger side fan (3 bolts) remove it.
then remove the belt by using the belt tensioner, then unbolt the alternator itself and unplug the connector. it comes right out.
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
brboy
Oct 5, 2015 11:34 AM
mars
Sep 28, 2015 11:03 AM
