Removing 97 Center Console?
I need some help removing the center console. I had all the screws out that I assumed I needed, but I think there is a bolt or screw into this metal bracket that holds the stock radio in. Am I correct or do I have to take out the plastic around the steering column, glove compartment, etc.
You do have to remove the steering column cowling, and also get a screw or 2 that are up inside of the glove box. I believe you also do have to pop out the middle part, and get bolts down inside, there is a metal bracket that holds the stock headunit and pocket.
since you have 97, you should look up for this thread
https://acurazine.com/forums/showthread.php?t=171824
SidhuSaaB
May 30, 2020 12:40 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
searching helps to find such threads
