Recomendations for replace tires '97 CL 3.0
After ragging out my Staock Michelin MX tires i find myself in the Tire market.Anyone have any recommendations for replacements?
Quiet tires are a priority!
Thank's
Thank's
Get a set of the michelin pilot sports. A lil on the expensive side, but a definate upgrade to the stock mxv4s, I would say they run pretty quietly. The car handles and corner ALOT better than with the stock tires. Tire Rack rated them near the top in their tire tests.
DAN
acuradan69@aol.com
1st gen CL w stock rims/205/55/16 pilot sports.
DAN
acuradan69@aol.com
The CH95's are NOT a good replacement for the stock MXV4's!!! I just rotated the CH95's to the front (and the MXV4's to the back) and the handling is horrendous. The front end washes out easily, the tires squeal like pigs, and the sidewalls are super soft. I run 38 psi up front.
I just noticed that you live in FL... which means that there's no reason to even think about running all season tires except for the comfort and noise issue.
Originally posted by Iceman:
<STRONG>Not to sound like a snob ('cause I'm all for finding great values), but I'd be a little worried about putting $71 tires on my car!</STRONG>
Ok, summer tires=wet/dry. All season=wet/dry/ice/snow. There are very few (if any) all seasons that can stick in the rain like a summer tire. Why? For decent snow traction, snow must be retained within the tread. For decent wet traction, you need to eject water out of the tread.
Also, summer tires are formulated to be sticky at temperatures over 40 degrees. All seasons try to operate well from anywhere from 0 to 100 degrees, which doesn't happen.
So, all season tires are a compromise in every way.
The $70 Kumho 712 is no joke. Don't knock em til you've tried them (I have a set on my WRX for the street and I have a couple friends that autocross on them). No, they won't stick quite as good as Yoko AVS Sports or Bridgestone SO2PP's or S03PP's, but at half the price, they don't need to.
On the other hand, they outstick Neato's "tuner" tires, Hangooks, Dunlop W10, etc... all of which play in the same price range.
If you only care about dry traction, get the $80 Falken Azenis. It's the closest thing to an R compound tire, but don't play too hard in the rain.
[ 08-17-2001: Message edited by: RidinLow ]
OK.. I feel the need to say this... AGAIN...
TOYO PROXES T1-S = Best investment in tires for performance, ride comfort and reliabilty... not to mention a mean agressive tread pattern!!!
the only down fall is slightly higher road noise depending on pavement...
rseb4agze
May 3, 2016 07:41 AM
cammy5
Sep 4, 2015 11:26 PM
asahrts
Sep 4, 2015 05:55 PM
